Rock Lights
Those are enormous.
Yea they are - so I'm not sure if I can place them reasonably or not. Depends on their lite pattern - if its as broad and brite as I hope it is, it just might work. Like I said, I have to crawl around under the Jeep at nite with one of them and see what I can come up with - if anything. Its way down on the list of things to do though, so its going to be a bit. My first place to try is on the inside edges of the "shovel" to see what I get...
I found that the key is to have more but dimmer lights in strategic locations. Less shadows that way.
What tape are you using to attach your lights? Or is bolt-on the way to go?
I use these, bright enough. Been in for about 4 years. I also used these as extra lights inside the cab.
SUNPIE Pure White LED Rock Lights Kits with 6 pods Lights 6000K for Off Road Truck Car ATV SUV Motorcycle Under Body Glow Light Lamp Trail Fender Lighting (White) https://www.amazon.com/dp/B019ODAK26/?tag=wranglerorg-20
I too purchased these and some Neodymium Magnets and bolted them on to the leds.
I have ten led lamps and I can reposition them if needed. Purchased some 2 conductor 18ga cable and tapped at the locations of the LEDs.
I have 6 KC cyclones sitting in the garage, ready to be installed. Couldn’t stomach the 300 some odd dollar price tag for the kit, so I bought pairs of lights with harness from north ridge. I think I spent about 135 bucks for them. I’ll wire them into my relay center to turn them on and off.
