Changing the ride height will not fix that rub without also addressing the shock's travel bias. Shocks determine the suspension travel. Or a smaller tire could be used.
Or identify what specificly the tire is rubbing at full shock compression and decide if it matters. If the tire is contacting the flexible fender flare, then don't worry about it. If the tire is mashing into sheet metal and tearing up the fender and tire, then there is something to consider addressing.
Yes i know it needs new shocks for sure, old RC springs and shocks.
I think its rubbing the flares as I don't see any fender damage.
I just know its time to put some higher quality springs and shocks on.
