No, axle CL to the ground X2. Thats the accurate way to do it by measuring.Is your way different from the correct way?
Or calculate it out like Blaine
Do you just come to strt arguments because you’ve contributed nothing to this.
It really doesn't have to be this hard. Nothing has to be measured. Observe a specific verified MPH. Note the matching RPM. Punch those numbers into the calculator with accuracy on the other parameters and then alter the tire size until the calculator results match what you observe in the vehicle. That is your tire size for the purposes of the calculator.And before you go down the rabbit hole of trying to figure out the effect of altitude and ambient temperature on your tire pressure, read this:
https://www.coyoteents.com/temperature-and-tire-pressure/
Oh well, in that case, let's just make it as confusing as possible with all the extraneous information that just confounds the simpleton further.True, but measuring actual speed and rpm with a drive down the highway will confirm the tire diameter that was extrapolated for those of us who are doubters and those of us old enough to remember Ronald Reagan's sage advice to "trust, but verify."
... "trust, but verify."
Most gear charts are calculated in direct drive, not overdrive.So according to grimm jeeper my jeep should hit 60 at about 2260 rpm with 4.11 gears on 31” tires. I just replaced the speedometer gear so my speed is acurate (i tested it with a gps speedometer) and its hitting 60 at about 26-2700 rpm. This is all in 5th gear by the way.
Grimmjeeper calculator is not a gear chart.Most gear charts are calculated in direct drive, not overdrive.
Ok. Was the value entered for 5th gear correct? A 400 RPM difference sounds like it could be the difference from 1;1 to OD.Grimmjeeper calculator is not a gear chart.
No idea, but if you go look at it, it don't take long to figure out it is just basic math with one variable that proves the rule of garbage in, garbage out.Ok. Was the value entered for 5th gear correct? A 400 RPM difference sounds like it could be the difference from 1;1 to OD.
