OMG....is Jerry, Chuck..... really lieutenant Dan???
Dang this is getting deep!!
If he is, does that makes Andy........Gomer Pyle
![Thinking face :thinking: 🤔](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
If he is does that makes Andy........Gomer Pyle![]()
Has any one actually seen or experienced damaged rear Rubicon Lsd gears first hand?
Yes I have seen a couple first-hand.Has any one actually seen or experienced damaged rear Rubicon Lsd gears first hand?
Yes, seen them first-hand.
I didn't see either breakage actually happen, I just saw the broken locker's LSD parts later. The first one I saw was in Blaine's shop.Was it a pretty extreme situation- like Johnson Valley- Were they beating on it pretty hard
I didn't see either actually happen, I just saw the broken LSD parts later. The first one I saw was in Blaine's shop.
I remember reading a post some time last year that someone's rear locker had taken a crap. I did the locker bypass last year and pretty much lock my rear locker anytime I'm off pavement, two wheel drive or 4wheel drive.
My theory is we don't see a huge failure rate of the LSD inside the Rubicon's rear locker because few Rubicon owners actually wheel them. Fewer yet wheel them hard enough for it to be a problem.I’m sure it happens - and if you look, especially in his word- carnage is pretty common
I’m just thinking as far as the regular user if it was a big liability we would see a large failure rate
I lock my Rubicon in 4 low simply because if I’m in 4 low it means I’m in some tough stuff in the first place. People always tell me my YJ is a POS because it has square headlights. Now my TJ is a POS because it’s a Rubicon. Lets see 05 Rubicon - PCM, OPDA and LSD are all going to fail now.
My friend Mike's rear Rubicon locker failed when his Rubicon was only 3 or 4 years old. He wheeled it once or twice a month and used it as a daily driver. It was back when you could still get TJ Rubicon replacement parts from Mopar. He replaced it with a front locker and last I heard from him the front, non LS, locker in the rear was working great for him.
That seems to be the case, at least my rear Rubicon locker is still holding together.On this thread, questioning if failing to engage them kills the rear lsd, the answers seem to indicate both lockers and lsd fail rarely.
Yeah , occasional locker failures happen on all brands and systems- but the numbers just aren’t there.
