Wondering if you could help me out with the installation of the Savvy Mid-arm (complete kit)...on my 2005 TJ Rubi.?
I'm following the on online instructions that Chris posted (https://wranglertjforum.com/threads/savvy-mid-arm-install.16426/), however, I've run into an issue with the rear control arm-to-frame mounts; I measured from the skid plate center bolt 10" to the rear and the bracket ends up on the the skid plate's rear bolt rivetnut...I sent an email to Savvy with pics and he said "you must have to use 12", which conflicts with the instruction for my 05?
When I cycle the suspension it's def too far back, and I'm worried I won't have enough adjustment to move it forward...I think I need to move it to 10"...just looking for a reference dimension from center of axle at stuff, extended, or ride height to a frame point?
