I'm installing Currie Double adjustable Control arms on my rig. Trying to follow this post
https://wranglertjforum.com/threads...-control-arms-on-a-jeep-wrangler-tj-lj.17062/
and the poster makes it seems as though the uppers should slide in and out easily. Mine are not. The point I am at...
Any ideas welcome...hopefully @mrblaine, @jjvw, @Jerry Bransford, @TJDave @Chris will chime in.
Any ideas where I might be missing something?
- I removed the springs, the track bar, disconnected the bottoms of the shocks, and disconnected the anti-roll bar.
- I removed the DS lower and then used it to set my control arm lengths to factory lengths buy adjusting them until the bolts fit thru the new and old holes easily.
- Put the Drivers on the vehicle Removed Passenger lower, put it on the vehicle.
- Set the lengths of the lowers to be centered on bumpstop at full compression.
- I removed both uppers and installed the new ones. Driver's went in at factory length, passenger was adjusted until it fit easily.
- I reinstalled the springs, trackbar, and shock bolts. I left the anti-roll bar disconnected for now. Everything is assembled loosely but Jeep is sitting on its own weight.
- I started the adjustment process with squaring the axle. The lower bolts were bound. I monkeyed around jacking it up in different places until I was able to easily remove the bolt. Jacking the pinion up is what removed the load on the control arm. After that, I was able to easily remove a bolt and make an adjustment on the driver's lower to square the axle (needed to move about a 1/4 inch). Usedt a ratchet strap to pull the axle in and slid the bolt in.
- Checked square in two places and its square.
