Shock length with Savvy mid-arm
Larrybortz
Iowa
What is the length of shock that should be used with the 4inch lift ( rockjock ce-9131 rear and ce-9132 front springs assuming I have it setup to utilize the full travel of the spring. I have the jeep completely torn down at the moment so modifying and outboarding can easily be done and would like to order shocks. I'm thinking smooth body fox with dsc from accutune unless someone has a better option.
Same length as a short arm. And just like a short arm, don't do any outboarding until you know the final ride height.
Reactions: Bigmac and rasband
I don’t have personal experience but several have had success with Alltech.
If you search that business name on the forum you should be able to find several posts
Reactions: jjvw and rasband
Definitely, I would call Wayne at alltechmotorsports.com. You won't get through probably for a few weeks though with KOH so soon.
Reactions: jjvw
Was just reading some earlier posts on this and looks like that's the place to go to.
Fox shocks, and likely others, were very hard to find the last couple years, but maybe that has finally let up (I hope so!).
