Hey, guys, I noticed when I drive I get a clunking noise, it happens when I am turning seems like something shifts than when I turn the other way I hear the clunk. The sound seems to be underneath in the middle / towards the rear. Any ideas?
Sounds can radiate...Hey, guys, I noticed when I drive I get a clunking noise, it happens when I am turning seems like something shifts than when I turn the other way I hear the clunk. The sound seems to be underneath in the middle / towards the rear. Any ideas?
only moving and when turning like mentioned... not sureSounds can radiate...
Stationary? Only moving?
Both?
2wd, 4wd?
had someone rattle the crap out of it, dropped the tranny skid plate a week ago and tightened it all back down, everything good there. could not seem to find the noise, going to have to keep shaking itGet under there and start wiggling everything. It could be a simple muffler hanger broke or it could be your transfer sliding on a broken mount. Or anywhere inbetween. The only way to know is to get down there and find out.
those are all good, thanksI would suggest also checking the transmission mount bolts as well as each of the control arms.
d-
No worries, that's a normal trait of a Dana 35 rear axle which you almost assuredly have from that clunking you're hearing. A Dana 35 axle has a c-clip design, it uses a pair of c-clips to hold the axle shafts in. The axle shafts need to be able to be pushed inward probably 1/2" or so so the c-clips can be removed to remove the axles. The c-clips normally sit inside a recess so they don't fall out. Because the axle shafts can move in/out that 1/2" at time, they can produce a very solid-sounding clunking sound. So if you have a Dana 35 as it certainly sounds like you have, no worries... it's completely normal.Hey, guys, I noticed when I drive I get a clunking noise, it happens when I am turning seems like something shifts than when I turn the other way I hear the clunk. The sound seems to be underneath in the middle / towards the rear. Any ideas?
Jerry, I have a Dana 35, and after the tailpipe hanger was replaced, I didn’t hear the clunk. But I only drove it 4 miles back home, where it’s been stored in the garage since then. I’ll have to check it out when the salt and crap are gone from our roads.No worries, that's a normal trait of a Dana 35 rear axle which you almost assuredly have from that clunking you're hearing. A Dana 35 axle has a c-clip design, it uses a pair of c-clips to hold the axle shafts in. The axle shafts need to be able to be pushed inward probably 1/2" or so so the c-clips can be removed to remove the axles. The c-clips normally sit inside a recess so they don't fall out. Because the axle shafts can move in/out that 1/2" at time, they can produce a very solid-sounding clunking sound. So if you have a Dana 35 as it certainly sounds like you have, no worries... it's completely normal.![]()
Then what you heard might have been from the tail pipe. But the axle shafts in a Dana 35 will for sure make a clunk once in a while like when backing out and turning on a sloped driveway. I had a Dana 35 until around 1999 and it would make that clunking once in a while, it scared me until the above was explained to me.Jerry, I have a Dana 35, and after the tailpipe hanger was replaced, I didn’t hear the clunk. But I only drove it 4 miles back home, where it’s been stored in the garage since then. I’ll have to check it out when the salt and crap are gone from our roads.
