Strange Clunking Noise
benny3577
Iowa
Ever since I bought my Jeep a few years ago it has had a clunking noise that seems to come from the back end, particularly the back passenger side. I have laid underneath and yanked on various suspension components (shocks, control arms, track bar, etc.), but nothing is obviously loose. I was hoping someone has experienced the noise (played in the video below) before and could give me any ideas as to what it could be. I will likely replace the control arms soon as they are original. I’ve attached a few video. I’m talking about a sort of clunking noise that occurs when I go over uneven terrain.
The video is here.
The noise is at 0:09, 0:20, and 0:26.
Thanks for the help.
Really hard to pinpoint without being there in the Jeep. I'm really not sure, but your description of the sound is pretty much spot-on with my recent description of a problem. My issue turned out to be the front driveshaft. The splines (for whatever reason) gradually worn down, making them tapered on the ends and the shaft's rotation to be more of an oval motion than a circular one. I never heard the clunking sound from mine until I slowly crossed uneven terrain.
https://www.dropbox.com/s/82out6sxk0baco0/VID_20190719_210324428.mp4?dl=0
This could be a bunch of things.
Control arm bushings - can you duplicate the sound on load? Meaning, can you let the clutch out in first fast and hear /feel the clunk? I was able to "lerch" forward with my manual to duplicate a rear upper CA bolt not torqued, causing a clunk
Swar Bar links - should be able to tell if they are worn visibly. They will have to be pretty worn to clunk like that
I had a buddy sit under my jeep while I lurched forward a bunch of times over and over to nail down the sound/clunk. Be careful doing it though
Reactions: bedhed
Just a guess, but I’ve had similar clunks on my Tj and xj. The Tj had worn rear sway bar bushings on the axle which are cheap and easy to replace. The xj just had one loose rear top shock mount that needed tightening but didn’t appear loose. When trying to find the sounds, neither would budge from me pushing or pulling on parts while underneath, but having a buddy stand on the bumper and jump up and down cycled the suspension just enough to make a guess. I also uselessly took apart, drove around the block, and put back a lot of stuff trying to find the source so it can definitely be frustrating. Good luck
Thanks, everybody. I've replaced the transmission mount and the rear sway bar bushings on the axle over the last few days. I think I'll have somebody bounce on the front bumper and see what is going on when I get a chance. I was stopped on a smooth and paved uphill incline the other day and let off the clutch rather quickly in first gear and the clunk presented itself there too. Does that give any more hints?
I'm still thinking either the shaft. Maybe the control arms like the other guys mentioned. I guess that would depend on how hard it lunged forward, yeah?
Did you get a chance to check for play in either one of the prop shafts?
I didn't lurch too hard, that's for sure. Unfortunately, I'm over 250 miles from the Jeep right now because I'm at school. I'm going to have my brother take a look and I'll report what I find out.
Control arm bushings and/or bolts not torqued properly. Have you replaced any CAs lately ? Were they torqued properly with tires on the ground ?
You were indeed correct about the control arm bushings. I changed them this weekend. The passenger-side rear control arm had a bushing that wasn't even pressed into the arm anymore. The clunking noise has now seemingly disappeared.
Awesome glad it was an easy fix. Re check the torque after a couple hundred miles just to make sure they are still tight.
did this only happen when in 4wd?
