Sluggish Acceleration
A brand new AX-15 from Novak or Advanced Adapters is just under $2k. You'd probably need to find another 231J or research the shaft lengths.
I essentially did a 2.4 swap when I rebuilt my 97 in eight days.
It's an option...
Are you able to cut off the 2.4 mounts and reuse them?
The engineer in me wants to figure out and fix the problem but at the same time depending on what’s wrong cutting my losses and upgrading might make more sense.
Technically speaking I can't answer that...I cut off and discarded the 2.4 mounts and transfered over the 4.0 mounts from my bent frame. The welds are shitty and easy to cut.
I also had to mess with my steering mid shaft mount...the 2.4 brackets land right at the mount and the 4.0 is set almost a foot farther forward.
Reactions: Stretch97
Do I need the intake to be on during the compression test?
valve pictures, in cylinder order 1-2-3-4
They look cleaner than mine...but it's the seats that count... compression test/leakdown test will help answer some of those questions.
@CharlesHS @macleanflood @JKP @Artsifrtsi
Just got back from a long weekend out of town and did my compression testing. Two compression readings per cylinder. Here are the results.
Dry Test:
1: 150/150
2: 172/172
3: 170/170
4:180/180
Since cylinder 1 was an outlier so I did a wet test on it.
Wet Test:
1: 170/170
Since the wet test enhanced the PSI up to where the other cylinders were, I’m going to assume my issue is the rings on cylinder 1 are bad right?
Dry Test:
1: 150/150
2: 172/172
3: 170/170
4:180/180
Wet Test:
1: 170/170
Did you just do a compression test or a leak down test ?
The leak down test would tell you if the exhaust or intake valve was leaking by....
Not necessarily bad, but the compression ring is not working as well as on the other three cylinders.
Just the compression test for now. No local shops have kits I can rent/borrow so I’m waiting for the leak down kit to come in.
Update:
Decided to run the compression test again today just to double check. I did a wet test for them all and surprisingly everything was close this time.
1: 190/190
2: 195/195
3: 195/195
4: 205/205
Still waiting on my leak down kit but I thought this was interesting.
Well I think I found my problem during the leak down test…
  • Wow
Reactions: lBasket
Pull the head. At a minimum lap the valve and replace the seals.
Alternatively go nuclear and have a machine shop go through the head...fair warning that could take months and no guarantees these days anyone does a quality job.
You could also purchase a Clearwater head.
I'd lap the valves and change the seals. New seals come with a Felpro head gasket kit anyways.
Thank you for all the help guys! I’m mechanically inclined but I’ve never gone this far down the rabbit hole, so I appreciate all the tips.
I do have an extra head from a blown motor… maybe I could use that or just say screw it and get a new one
Machine shops use a tool to check valve leakage before assembly.
You don't have that tool...so you either would need to engage a shop that does on that used head...or stick with the one you know exactly where the problem is.
My guess is you can fix this problem with a $115 head gasket kit and $5 in valve lapping compound.
https://www.amazon.com/Fel-Pro-HS9076PT4-Head-Gasket-Set/dp/B0016ZIZUK?tag=wranglerorg-20
Just for documentation/ to avoid confusion for others that may follow this thread, I found the correct fel-pro kit on Amazon since mine is a 2.4L
FEL-PRO Head Gasket HS26206PT-1
Your link still helped me get to the right spot. Thanks!
Reactions: macleanflood
Removed my link and thanks for catching that!
@CharlesHS
So I decided to do some more testing just to double check the problematic valves and I found something interesting.
When cylinder 3 was at top dead center (TDC), there was no leakage. I then rotated 360 degrees for the second TDC position during the combustion cycle, and this time both the intake and exhaust valves were leaking!
Does this suggest the issue isn’t limited to valves? Let me know.
