Anyone selling an aramid product will be quite proud of that fact and make it known through some tidbit in the description.How do we distinguish between UHMW and Aramid material?
Great idea, I do have a die grinder so this would work.If you have a die grinder, you can get a tapered stone (coarse grit is quicker) and wobble the tool around the hole till you like the profile. I used a stone on my angle grinder that looks like a die grinder stone but a little bigger and has a 5/8-11 fitting. The stone tended to eat up quick but left a nice rounded shape to work around the shackle tab hole.
I think mine was a little thinner than 2", maybe not but know it was cheaper, like $8 or so. I have a McFadden-Dale Hardware up the street from me. it is a home depot on steroids, but no washers and dryers.Great idea, I do have a die grinder so this would work.
English translation= $$?Anyone selling an aramid product will be quite proud of that fact and make it known through some tidbit in the description.
Can't remove something that was never there.So... is everyone removing the steel shackles from their bumpers now; or just when it's time for a recovery?
I removed mine I got tiered of hearing them clanking when they would bang back and forth on my bumper. I still carry one or two but my soft shackels one are my go to ones first.So... is everyone removing the steel shackles from their bumpers now; or just when it's time for a recovery?
Seriously, how many are needed? Same as my Steel shackles? 4? 5? I have one 3/4" shackle on each of our work trucks, along with a 3/4 kinetic rope. I figure I would make do with that on the road, the trail is different.
I notice on the true soft snatch blocks, they are set up for a soft shackle. I like the idea of a piece of aluminum over my heavy steel block. Doing it right would probably save me 20-30lbs of recovery gear weight.
The easy answer is they are a shackle and do what a shackle does. If you felt the need to carry 2 steel, carry 2 soft. As you use them and find out all the things they are better at, you may decide you want more. I carry one steel so I have something I can use where it isn't prudent to tear up a softie.I want to add a few questions. I will lay out the general idea for my questions first. I am looking to make recovery safer and easier for my family. That is the basis of posting this thread. I am trying to wrap my head around the soft shackle idea in hopes of ditching the heavy and hard to use shackles (and snatch blocks).
I did some shopping on amazon and found that the "less expensive" softies had descriptions written in chinglish and probably made in china. The American made softies are 3-4 times the cost and proudly state USA made. I have never used chinese shackles (steel) on my Jeep or in industrial applications. Can someone share if the soft shackles are all the same?
I would tend to buy American anyway, but when safety and specs come in, I will usually default to American made. but then I would only have one softie to hang from my bumper until I could afford another softie to match, it has two tabs, would not look as cool.
I wouldn't try it but I don't have good luck with stuff like that. The concept is sound.
Mine are almost an exact copy of yours. I may go back and round mine off a bit more.I used a chamfer bit I got at Home Depot and then cleaned it up with a dremel. Not total perfection, but doesn’t matter to me. Hit it with some spray paint afterwards.
Picture makes it look slightly worse than it is. Pretty rounded all the way around with no edges.
Folks need to be aware that while 82 degree is the most common for what we do, any metric flat head screws will be 90 degree. There are also quite a few 100 degree SAE flat heads so everyone needs to check the angle before assuming they have the right tool.This is a helpful tool to have. The 82º taper is what countersunk bolts and machine screws use. Could be used for rounding to, cut the bulk of the taper, then fine tune with a stone or emery cloth. Notice that it is the cheaper of the available sizes (we could use for this job). Dunno why.
https://www.amazon.com/dp/B00N40AEY0/?tag=wranglerorg-20
I did not know metric was 90 (important to know). My shop does a bunch of "plow bolt" holes and all of them are SAE and 82. I did not have very many metric tools till this TJ.Folks need to be aware that while 82 degree is the most common for what we do, any metric flat head screws will be 90 degree. There are also quite a few 100 degree SAE flat heads so everyone needs to check the angle before assuming they have the right tool.
It also helps to know that not all manufacturers sell them by the included angle. Some sell them by the angle of one side.I did not know metric was 90 (important to know). My shop does a bunch of "plow bolt" holes and all of them are SAE and 82. I did not have very many metric tools till this TJ.
