Solar Yellow LJ restoration / mild mods
jblues1969
Waxhaw, NC
I got this poor baby at a reseller for auction vehicles (and paid too much for it, sadly, but it was my first time) just over a year ago.
Carfax told me it had been in 3 accidents during its lifetime, but the last one totaled it.
As you can see, it took a hit on the driver side front.
Aside from that, it had minor body damage all over from rough treatment. All the plastic trim and mirrors were road rashed. Prior owner ran wires everywhere, put in a horrible aftermarket security system and light bars. Drilled holes everywhere to hang crap on it. But other than that, it looked solid.
I have a buddy (a band-mate) that owns a collision shop and he offered me the friend discount as long as I was willing to wait behind any other work he had to do. That's why this took so long.
We replaced the wrecked suspension with a RC 2.5 inch lift kit. (Yes, I know RC is trash, but this is going to be a mall crawler. It's been through enough in its life)
I scored a new fender and a set of 5 brand new JK wheels and tires for almost nothing on FB marketplace.
The "other things" that were bad that we didn't notice at the time of purchase were as follows:
1. Transfer case was broken in half - Luckily not a Rubicon, so finding a replacement was fairly easy and cheap.
2. The wreck pushed in the grille enough to damage the cooling system, so the radiator, fan, clutch, water pump, etc needed replacing.
3. Previous owner had apparently ordered the wrong cold air intake and frankensteined it (I particularly like the little air filter on the valve cover). I replaced it with a new K&N.
4. This was the scary thing - the motor mount on the driver side was broken off the block, and it took all three bosses with it. I thought this meant new engine, but I googled and found out about Brown Dog motor mounts. After seeing they were 6 months behind on orders, I found a guy on Facebook that bought but ever used some and he was willing to sell them to me for his cost. Since those mounts use all 7 bosses on the block, I was good to go.
5. The last nasty surprise was to find that the axle housing that we'd inspected was bent after all. I looked into a replacement, but the local 4WD shop told me they could straighten it, so I let them do that, as well as ball joints, alignment, front driveshaft, etc.
6. The pleasant surprise was that the brakes were new all the way around and didn't need any work.
Finally, I got it home with the paint and body work done and started putting on all the stuff I bought over the last year.
Now I get to DIY all the little things!
That's a project and certainly there will be a million little things. But if the frame is straight and not rusty, it might be a great save(y)
Reactions: MikekiM
The frame was perfect (aside from a slight pull we had to fix from the wreck). It was coated with mud, but no rust at all anywhere.
Funny story - I sold the old wheels and tires and the buyer told me they were all warped. He put them on as-is and tried to drive with them. He later called me back to apologize. They were packed with mud and once he washed them out they were OK.
Reactions: MikekiM and Woodrow
It looks like you started with a pretty dirty/neglected vehicle. Make sure to clean out inside of the frame (hose/compressed air). TJ (LJ) frames often rust from inside to out, especially between the front and rear lower control arm mounts. Many here rec drill holes in the bottom of the rail just behind the front LCA and right in front of the rear LCA to help keep water from sitting in side and a bore scope is useful to look at the inside.
Reactions: MikekiM
I have seen videos about that, and I've got it on my radar. Got to get over the heebie-jeebies about drilling into the frame, LOL.
Reactions: Woodrow
I'm pretty much against doing anything to a Jeep that is permanent and can't be undone but drilling frame drain holes is a must
Great looking paint job by the way. Any pics of the paint job in progress or info on the process?
What size bit for drilling the holes, do you think?
I would recommend 1/2", big enough for water to drain but no bigger. If you have a manual tranny, you'll probably already have a 9/16" hole in the bottom of the frame just behind the front control arm mount. Mimic it at the rear. With an auto, a nutsert will be there for the tranny skid, and you'll have to add another hole.
Reactions: Woodrow
After drilling, try to get a round file in there and clean up the sharp inside edges of the hole. You're going to stick your finger in there to check for rust, dirt, and moisture some day. You don't want to walk away missing a finger. :(
I did 5/8". This works well but 1/2" or 9/16" should be fine.
cf3fcda4-2d18-4215-b002-1c916c9f3741-jpeg.324997
Exactly what I did. Front as well. I was surprised how much came out of the frame rails when I cleaned them. Followed up with Fluid Film and POR 15.
Love the repaint. Yellow is my favorite color!
