Here is a good thread on cutting brakes.
https://www.rockcrawler.com/forum/threads/cutting-brakes.3806/
been diggin around over there at lugnut 4x4.Same. I've never had any luck with the hat ebrake systems.
I've been looking at these.
https://www.ruffstuffspecialties.com/R2262-A.html
i really didn't tug any harder, than the rest, it was a slow steady pull. almost seems like those 3 were super tight and the others not so much.I found that I had to be really careful with the pinion bolts when I did mine. My pinion support was tight enough that it required a hammer to get it in or out. When installing it, I’d drive it in and the bolt holes would not be aligned - and there was no twisting it once it was in. The trick I found was to set the pinion in place, get all the bolts started, and then drive the pinion in.
In theory setting the pinion height on 14 bolt is easy - but in practice when the pinion is tight it’s a pain in the ass.
That not a gasket - that's the shim for setting the pinion depth.i really didn't tug any harder, than the rest, it was a slow steady pull. almost seems like those 3 were super tight and the others not so much.
i can see a tin gasket in there hope thats kept the surfaces from lockin.
and big nasty gobs (all fine dust) on the magnet in the diff but no evidence of anything being the culprit.
thank you..........i intend on lookin but wanted to ask.That not a gasket - that's the shim for setting the pinion depth.
Your install kit will have a bunch of 'em.
It does sound like the seal came apart. If memory serves, the hub seal is certainly one piece.thank you..........i intend on lookin but wanted to ask.
behind my hubs there were 2 loose rings on each side, they look to me like the rear seal came apart. what is left in rear of the hub is just a rubber ring. i was guessing the rubber and the 2 rings should all be 1 part. any thoughts?
i'm about to dig into the billavista 14B bible again
no, not weight.....just my being unsure the sys can support the addition of those huge calipers without problems. i already increased the caliper piston mass by 100% from stock and now i'm trying to move that needle to more like 200%.Why such an aversion to the stock disk brake setup - is it all about the weight?
The rags in a bucket trick is exactly how I did it….well, after the first time anyway.no, not weight.....just my being unsure the sys can support the addition of those huge calipers without problems. i already increased the caliper piston mass by 100% from stock and now i'm trying to move that needle to more like 200%.
@Fluxor mentioned "right master booster combo" what is that vs what i got? (just a larger bore MC).
Blaine could tell me in like 3 seconds but i hate draggin him into my messes, i'm sure he would label a waste of time.
i'ma fill a bucket with some rags and put it under the assy as a catch, so i can give it a few nice whacks after i warm it some.
the 2500 MC has a 37mm bore, i assume that ain't goona fit a TJ booster the 2500 booster is affordable but whats involved in getting that in place of what i have now, not to mention i think that sucker is about 3" larger in diameter. if i read correctly.I used the ram 2500 master. Worked great. It’s a volume thing. Your booster provides the force the master distributes the volume. They need to be matched to work.
There are other master cylinders that will also work.
i got that bastard, put some heat to it and really had to lay into it......knockin on the back of the yoke proved better......., some prick put lock tight on that F'r. all over the assy flange and on the bolts. the 3 that broke were full of it. got those bitches out too.The only way I could ever remove the pinion was to use a heavy punch directly on the pinion gear, and a 4 or 5 pound hammer - hard. It was that way even pulling it out over and over doing the gear setup. That’s definiately what I meant ealier when I said it was a pain in the ass. Good luck, man.
