Sony XAV-XA3200 Head Unit Install
Thanks Andy!!!!
Will get an order over to Crutchfield for the radio and install kit.
Really appreciate the write up and fast response to my inquiry.
Reactions: AndyG
Let me know if running CarPlay and if it’s G2G on this unit.
I use Apple CarPlay to run Gaia GPS for off-roading. Works well! I also use Waze from time to time.
My only gripe is that I wish there was more adjustments possible to the rectangle shown on the rear camera view when reversing. I can't get it to match my camera position above the license plate.
Andy
Reactions: RocknLJ and AndyG
Thanks Andy!!!!
Absolutely love it! No cutting and I used on old switch blank I had laying around for the usb.
Reactions: AndyA and AndyG
Thanks, I just measured the usb housing and then dremeled the proper sized rectangle in the switch blank. Looking back and not that it would be much of a difficult task but I wish I would have moved my hardtop switches over towards the axle lock switch and put the usb in the first switch location. Personal preference I suppose but something to think about if you’re going to have it all apart. I am stickler for not wanting to cut holes in the dash or any other panel for that matter figured I had a couple of extra switch blanks laying around in my Jeep parts box so cutting one those up did not phase me.
Reactions: RocknLJ and AndyA
Great idea.
I also don’t want to mod this LJR with too many extra holes besides the one in my wallet.
Crutchfield offers to wire up the cable connectors for Jeep and radio so it is plug and pray.
Did y’all go that route or wire splice yourself?
My time is limited these days so was thinking of paying them the $24 to do it.
No stranger to wiring things as my other passion is restoring vintage tube guitar amps.
Just trying to save time…
Plug n play all the way!!! Only soldering or crimping required is from the radio pigtail to harness pigtail. Once your harness pigtail is soldered up to the stereo bring the stereo back to the Jeep and plug it in. Fingers crossed everything goes as intended and you have a working radio!
Wife texted and told me just received the radio and stuff from Crutchfield. Depending on how some of the “other” issues on the LJR that I’m working on go, my plan is to install this weekend as I’ve been gone on biz trip. I did order the plug and pray adapter from Crutchfield so will report back on how everything works out.
Thx again David
This is how I installed my new head unit with front and rear cameras, microphone, USB connector and satellite radio. I chose this unit for the following reasons:
- double DIN
- doesn't require hacking parts out of the dashboard
- fast bootup time and responsive screen
- Apple CarPlay
- Satellite radio
- Front and rear camera support
- Physical buttons
Complete shopping list:
- https://www.crutchfield.com/product/item/default.aspx?i=158XAV3200
- https://www.crutchfield.com/product/item/default.aspx?i=220SXV300
- https://www.crutchfield.com/product/item/default.aspx?i=249CUB01 x2
- https://www.crutchfield.com/product/item/default.aspx?i=120ISOPK
- https://www.crutchfield.com/product/item/default.aspx?i=120956541
- https://www.crutchfield.com/product/item/default.aspx?i=120706502
- https://www.crutchfield.com/product/item/default.aspx?i=12040CR10
- https://www.amazon.com/dp/B08VJL2K5S/?tag=wranglerorg-20
- https://www.amazon.com/dp/B01NCA9XEI/?tag=wranglerorg-20
Here is how it looked at the beginning.
The wiring from the vehicle harness to the Sony unit was easy because the Sony and the Metra pigtail use almost the same wire colors (some kind of industry standard?). I wired the parking brake to ground. The reverse wire I connected to pin 33 of C300 (white with light green hash). Because that wire has to snake from the center of the dash to the driver's side outer footwell I used an inline spade connector so it can be disconnected.
Next I drilled a hole into the blank panel near the switches. On the back of the panel there is a marking in the mold to indicate where a circular connector goes (switch to turn passenger airbag off I believe) so I used that as a guide, drilling a hole and then using a Dremel to enlarge it.
The microphone is designed to clip onto a visor but I didn't want any wires showing so I converted it to panel mount and installed it at the driver's end of the defrost vent panel.
I put an M12 external circlip into the first groove in the mic and 3D printed a cover. I epoxied the cover onto the circlip to hide it.
After drilling a hole through the defrost vent cover I installed a 4mm thick 3D printed washer and then another M12 circlip. I think this makes it look nice and tidy and discreet.
The satellite radio antenna was the easiest part. I shoved it under the cover of the rail that goes across the back holding the speaker pods. I chose this location because according to the Factory Service Manual this is the factory location for it.
I 3D printed a mount for the front camera which bolted onto two spare holes in front of the AC condenser. I ran the wire around the driver's side outside edge of the engine bay, through the firewall and grounded it at a point a PO had created.
Power for the camera was tapped from the Run/Accessory wire going to the radio.
The yellow RCA connector plugs into the RCA to 3.5mm plug adapter however the Amazon listing for the adapter shows the wrong pinout and I had to plug the yellow connector from the camera into the white connector on the adapter (sigh). The important thing is that the ground is in the correct location on the 3.5mm plug.
The front camera is tilted down so I can see part of the front bumper.
For the rear camera I 3D printed a bracket to go behind the driver's side tail lamp. I originally experimented with putting it poking out of the spare tire but I wasn't happy with the sturdiness or the wiring routing so I changed to this. It's not ideal because it is so far from the center of the rear but it works OK. The printed part has a channel for the wire to run down, keeping it hidden as much as possible.
Originally I tapped power for the camera from the reverse wire going to the tail light, however that was not workable.
The Sony unit has an option to view the reverse camera at any time and also the guidelines could only be configured with the camera powered but the vehicle not in reverse. In the end I changed it to being powered from the same Run/Accessory wire as the front camera.
The Sony unit is double DIN but actually only takes up a single DIN space. The problem is the Metra mounting brackets. Rather than cut up the dash I cut up the brackets.
Here is the final mess of wires:
And here is the result.
I then added a custom wallpaper generated by the MidJourney AI.
Andy
Thanks for the thorough write up! I installed a double DIN right away when I got my TJ but it's been buggy and not a great screen so I used this thread as motivation to upgrade. I found the Sony XAV-AX5600 for same price as the OP's XAV-AX3200. Very similar features but the 5600 has a better screen. While I'm waiting for it to ship I stole the microphone idea but modified it some. I had also installed a phone holder up high on the trim piece above the windshield, it was not a great place for the phone so I moved the phone but it is a great place to mount the mic. I also had the four small holes that I wanted to cover up. I used parts of the old phone holder, a grommet, and metal clip to make it all work.
Reactions: AndyA
Very nice!
The front camera mount kept coming loose - something to do with the stresses on the 3D printed design. I decided to re-work it for the front bumper, sitting under a KC fog light.
Andy
