The above advice is good, just keep one thing in mind when choosing your speakers... look for the Sensitivity rating in the specifications and MAKE SURE the Sensitivity rating is 90 dB or higher. The higher the dB (decibel) Sensitivity rating the less power the speaker requires to play at a given level.
To illustrate that, a speaker rated to 87 dB requires twice as much power from the amplifier to produce the same volume that one with a 90 dB Sensitivity rating does. Every 3 dB change is either doubling or halving the power required.
