Does anyone have experience with a spare mounted rear storage rack? I want to makes rack that can hold a 5 gallon jerry can, 5 gal water can and cooler. I estimate about ~100-115 pounds, 10 gal * 8.5 #/gal + 20 for loaded cooler + 10 for rack. The rack would connect to the tire via a ratchet strap that goes around the circumference of the tire.
In your experience, can the spare and its mount hold this sufficiently? I mean tires support cars that should be fine. I have an aftermarket spare carrier made from 1.5” square pipe.
The other issue I’m thinking about is what happens if I have a tire fail and need to mount the rack on an unpressurized tire, will it still hold?
Anything else I should be thinking about?
Thanks in advance for your thoughts and wisdom!
