Spicer Extreme U-Joints
I'll stick with the sub $25 spicer replacements at 50-100k intervals. The kind of money they are asking for seems insane.
Reactions: J R and Alex01
What do these typically run for the standard Dana 30 axle?
4 grease fittings per joint?!?! No thank you. I'll stick with the sealed units.
The 4 grease points are because there are no needle rollers in these they are a smooth bore bearing and will need to be greased pretty often. It says off road only on these little jewels too. While they are pretty cool and do have a use, they're not for my application.
Reactions: MaloStapalo
