Steering doesn't return to center
YakTJ
Georgia
Today noticed that when turning left or right thru curves that the steering would just stay turned to the left or right. It doesn't automatically return to center if you let go of the wheel. Power steering fluid level ok. It is not hard to turn. Just doesn't return to center straight. Is it my steering damper??? Advise from all the experts please! Thanks.
Reactions: Shatto
That's a common symptom of insufficient caster angle which is what provides good return to center after completing a turn. A big suspension lift will reduce the caster angle, do you know what yours is? 7 degrees is factory but 5.5 to 6 degrees is fine for larger tires.
Jerry,
Only a 2 inch leveling lift on the front and tires are 265/75/16 BFGoodrich .
Reactions: Shatto
jjvw,
I think it has been this way for a while and maybe aware of it more today as where i drove this morning was really curvy.
Reactions: Shatto and KCsTJ
How is your toe-in angle? Your suspension lift height isn't tall enough to normally cause a significant loss of caster angle. A bad toe-in angle can also cause steering issues. Whatever it is your steering issue is very likely alignment related.
Reactions: Shatto
Searched the forum and found Jerry's post on alignment!!!! Looks like i can do that!!!
Thanks all.
You can and you will save yourself much heartache by doing your own maintenance and repairs.
Nobody will take the care and patience to do the job right on your own jeep but yourself.
You dont want professional repair shops putting their greasy paws on your Jeep
Tire Guys tell you to rotate and get an alignment every 7,000 - 10,000 miles.
Because I always have, I got a Lifetime Alignment from Firestone. But my Jeep has stock tires.
I suggest you consider same because all you need is to hit a submerged stump or slip onto a boulder.
Reactions: Boinked
My TJ (new to me) has the same symptom, steering will not center on its own. I checked the toe in and it’s at 1/8” with 31” tires that measure 29 3/4”.
It goes down the road fine, no death wobble, tires appear to be worn fairly even. What else could cause this symptom?
Assuming by your 31" tire size that a suspension lift with adjustable length control arms has not been installed, my only guess would be that your steering box is worn out. Assuming your toe-in is truly between 1/16" and 1/8" as you measured. Also make sure your tire pressure is correct, somewhere around 31-33 psi for your 31" tires.
Thank you for your quick response. I’ll have to do some research
The u-joint and bearing on my lower steering shaft are kaput. I removed the steering shaft and am in the process of getting a replacement.
I will let y’all know how it goes.
Update on my Jeep: found a used lower steering shaft for $50, cleaned and greased the needle bearing and viola! Steering problems solved.
I’m a happy camper!
Reactions: Mikester86
