You won't be sorry. If you are I should pay for it.This is so tempting since literally every other car I own has a LS.
Why not mount up dual wheels to the front of your TJ and run a Twin-six ? Go ahead and stretch the front clip 40" Displacement be damned.235 ft lbs in the final version.
Its at a way low RPM compared to most other gasoline engines, but could be lower. My beloved 305 V6 was more torque at a lower RPM, BUT it was an entire litre larger - and 2X heavier!
It would improve front traction for sure! World's first, last, and only TJ with a 702 CID engine!Why not mount up dual wheels to the front of your TJ and run a Twin-six ? Go ahead and stretch the front clip 40" Displacement be damned.![]()
Of course don't let the L-88 chevy guys see you put velocity stacks on an engine with a 2400 RPM redline.It would improve front traction for sure! World's first, last, and only TJ with a 702 CID engine!
I actually have dreamed of a bucket-T roadster style hot rod with that engine. Complete with personalized plates "702CID". Would be completely stupid, but fun! 4 separate 3 into 1 headers to side pipes, maybe even a custom intake with 12 velocity stacks...
I *think* the "Thunder V-12" version redlines in the high 3,000s somewhere (shooting from the hip, I don't remember offhand) - but either way - who cares? Its so stupid that anything goes! It'd be the only bucket-T in existence that tows its own mobile garage!Of course don't let the L-88 chevy guys see you put velocity stacks on an engine with a 2400 RPM redline.
Otherwise this build is so wrong I love it.![]()
Probably the only T- bucket that would be rolling on 10:00 -20's !I *think* the "Thunder V-12" version redlines in the high 3,000s somewhere (shooting from the hip, I don't remember offhand) - but either way - who cares? Its so stupid that anything goes! It'd be the only bucket-T in existence that tows its own mobile garage!
Thunder V-12 claims 270HP and 630 ft-lbs stock. Modified, 425 at 4,200 RPM, torque was apparently unmeasurable on the dyno used because it couldn't hold the engine back. They consider 5,000 RPM to be an absolute redline, but they do all this on 87 octane gas!Probably the only T- bucket that would be rolling on 10:00 -20's !
The info. I have shows 250 H.P @ 2400 rpm and 585 lb. ft @ 1600 -1900 rpm.
It's fun bench building shit we neither one will do!![]()
This ought to piss off everyone on the road to the trail and then even some on the trail !Redlines at 900 RPM or thereabouts, max power at around 600
And they'd be pissed off even before they smelled it!This ought to piss off everyone on the road to the trail and then even some on the trail !
I am too lazy to do the math at the momentbut I wonder what the lb. ft. of torque is !
The 8.0" stroke doesn't promote a 5000 rpm . redline .
I thought you meant 305 Chevy small block V8 but I just read about the GM big block V6 truck motor (which apparently had a 305 version) from the 60s. Is that your beloved? Was it in a Jeep?235 ft lbs in the final version.
That is well said-The 4.0 is definitely a reliable engine, which is about all it has going for it. I have a love / hate relationship with the 4.0. My 3.6 Pentastar was a fantastic engine to drive on the road, but as you shed light on, it’s not the best choice if you’re a DIY mechanic as the electronics are much more abundant.
