Juggernaut
Are you using Hp Tuners or Syked? I've not giving up yet on activation of a knock sensor on my factory PCM. The software is there in Syked. I also have had good luck looking at plugs to determine if I am getting close to detonation. I've had a few motors with nitrous and a turbo V8 making good power. None had a knock sensor and tuned by heat in the sparkplug.
Syked has 3 spark tables, warm up, egr off and egr on. The tables are egr off. Just watching timing while driving I'm not sure it ever uses egr on table. That table has greatly reduced advance.
I'm on HP tuners. the software itself shows Knock Retard but the channels providing the sensor feedback from the pcm are not being polled or supported. I don't know if there is a workaround for this or not. If HP tuners had better tech support, Id ask the question. If you do get this working let me know! I find reading plugs can be difficult with pump gas,(and Im not too good at it to begin with), and I know for a fact I wont hear any knocking over the hum of my worn MTR's on the street!
I'm not familiar with the terminology of Syked, but if your watching and its using EGR Off during normal drive than maybe EGR Off is the equivilant of the Part Throttle spark table in HP tuners. Under WOT does it use EGR On?
