twinjeeps
I'm running bigger (24.7lb/[email protected]) injectors , plumbed in an adjustable regulator, and I played with the pressure until my trims were averaged around zero at cruise. Then I've been logging with an innovate LM-2, using RPM, MAP, O2 1&2 and LTFT 1&2. I'm adjusting my fuel map according to the LTFT at RPM vs MAP. You can't access the AFR in here. Since it has stock narrow band O2, it's always going to be seeing rich/lean around 14.7 and trying to give you stoich through the trims, so that's it's fixed target.
If you want varying AFR on your table you'd have to run it on open loop all the time, and tune by wide band. To do so, you can disable the closed loop in a few ways in the fixed values, like raise the minimum closed loop enable temp to 190 or similar.
