Ive been work on my tj project for about a yr and a half... i put in a remanned motor and have taken off or fixed every nut and bolt many times with guidance from this forum or YouTube vids....so Wed was the moment of truth, time to start it for the first time.... AND NOTHING! Wtf! I went in the house half defeated and half mad! After 3 ish hrs i had about 6 differant directions to go on per suggestions from this forum. I checked fuses, relays, grounds, and plug connections.... under the dash are two plugs which can be used to either bypass or support the clutch saftey switch.... i moved the plug from right side to the left plug and gave it another try... F- ya!!!! Fired up and hummed as it should! THANK YOU THANK YOU THANK YOU, to the internet, youtube, and you guys on this forum!
