Hello everyone!
I bought a 2005 TJ Rubicon where the seller told me the CEL was on due to 4 cheap China O2 sensors - the error codes (he showed me via OBD): P0031, P0037, P0051, P0057.
I checked here on Wranglerforum and got 4 new O2 sensors from RockAuto:
- NTK 23158 (downstream, cyl. 4-6, bank 2 / sensor 2)
- NTK 23159 (downstream, cyl. 1-3, bank 1 / sensor 2)
- NTK 23160 (upstream, cyl. 4-6, bank 2 / sensor 1)
- NTK 23195 (upstream, cyl. 1-3, bank 1 / sensor 1) - this is the "newer" version of NTK 23018, the only one offered from RockAuto.
After installing them - still CEL with 3 of the 4 codes above: P0031, P0037, P0051 (read via VeePeak OBDCheck BLE+ with CarScanner App).
Today I checked all O2 wirings:
- All 4 sensor harness plugs have a common ground with good connections (G105 at lower right engine block - looks good and tight).
- All other 3 connectors of each 4 sensor harness plugs have good connections to the PCM connectors (harness side), no wrong grounds - so wiring should be good.
- When sensors are connected to the harness, the heater control pins have a connection to ground, all with 4.6 Ohm (Wrangler manual: 2-30 Ohm) - so heaters of the (new) O2 sensors should be good.
- PCM heater control connectors (at the PCM) have 3x about 75 kOhm against the PCM ground (C2 - pins 17 and 18, C3 - pin 17), and 1x about 6 MOhm (C2 - pin 18) - that’s the O2 heater control for O2 sensor 2/2 - this sensor doesn’t throw a code at the moment - would be P0057).
- With ignition on / engine off, all O2 sensors show 1.27V (Wrangler manual: 5V) - read via OBD. During engine idle, they show 0.04V - 0.06V and increase and decrease while driving (up to 0.9V).
- I swapped the ASD relay against the fog light relay (same spec), the fuse #17 (Power - 20 Amps) is also good.
Do you think that might be the PCM itself?
