How many O2 sensors does the 97 2.5l have. I need to replace them.
Sent from my VS988 using Tapatalk
Read the first post of this thread. It has the links and part numbers for the correct sensors for both.
So I found out that all my O2 sensors are NTK/NGK except for one, bank 1 sensor 2. Would it cause other sensors to fail or throw a Dtc?Your 98 has only 2 O2 sensors, whereas the later models have 4.
The only two O2 sensors you have are as follows:
NGK #23151 - Bank 1, Sensor 1 (Upstream)
NGK #23099 - Bank 1, Sensor 2 (Downstream)
I updated the original post to reflect this, as it was merely a typo on my part (though the part numbers were correct).
I'd replace both at the same time, it's the smart thing to do.
No, that would just cause a code for that specific sensor most likely.
Do these sensors go back to the fuse box, if so do you what position?
Hello Ken 97, did your mileage improve after replacing O2 sensors...?All replaced and no more error codes! Hopefully my mileage improves.
*To anyone looking to replace their O2 sensors* I'd reccomend a breaker bar, penetrating lube, and some kind of torch (all I had was a small propane torch). It took me just over 2 hours to do all mine and the breaker bar (or pipe slid over a ratchet) was needed a few times. I also bought the O2 sensor socket for $10 and it was totally worth it. Total investment was about $250 for all 4 sensors plus the socket.
My jeep threw another code today, it is P0141, 1/2 O2 sensor heater performance. It usually comes on, a few mins. after it is started.
When I replaced them a couple months ago, I used the NGK ones, should they go bad that quick?Replace the Bank 1, Sensor 2 O2 sensor with a NGK replacement and you should be good to go!
I'll inspect the wiring, I have cleared the code many times, and it is clear for a while then after a while it comes back. It comes on after a few mins of starting the motor. By the time I back out of the garage, and head down the alley it comes on.Oh, I must have missed that part. It shouldn't go bad that quick.
The only other thing I can think of would be a short in the wiring or a bad ground. I'd visually inspect the wiring harness to see if you notice anything. I'd also try clearing the code and seeing if it goes away, or comes back.
I agree, it still drives fine, but what happened to the old days when you could work on vehicles?I got a code for my lower rear O2 heater after my motor mount, body lift, and valve cover gasket and all new NTK sensors.
Couldn't find anything wrong with it such as a bad ground or broken connector.
So I drove it. Took it to the ORV park by us and dammed if the CEL light went off and hasn't come back.
Conclusion: I think you can drive yourself nuts with bullshit computer / electronic problems!
