So after my last trip I started the Jeep to go to work. started and immediately died. well that was weird. started again and it fired right up as usual. at stop signs and lights it died 3 times in the 4 miles i drive to work. Had to restart 3 times putting it in my parking space.
Died 6 times getting it back in the garage at lunch. Damn.
In the garage trouble shooting it would randomly die while idling.
After talking with Blaine we suspected maybe some bad gas with water and I added some water remover/ treatment to the fuel tank.
After the treatment it stopped dying but developed a bad misfire. no codes. the exhaust felt like my old harley.
Next was the Crankshaft Position sensor and I was due for new plugs anyway. found out the hard way I needed to pull all of the belly armor off and droop the whole drivetrain to change the CPS due to the tummy tuck.
got it all back together and same issue. wtf.
Buddy of mine pulled his coil on plug rail yesterday and loaned it to me. put it in today and she fired right up and running great. Put a mopar on order from rock auto and Ill be back up and running on the 19th when it comes in...
The old CPS had some cracking wires so it needed replacing anyway.
Between 2 mopar CPS ( got a spare), mopar plugs from the dealer, and a new mopar coil on plug rail, The Jeep budget is a little over this month....
old cps wires cracked. Had the harness routed around the oil pressure sensor incorrectly, now that thats fixed the new CPS should have a little less tension.
