One goal for this build was to update it with auxiliary lighting. Traditionally I have not been a big night wheeler, thus the first build only had stock lighting for the majority of its existence.
This thought process was changed after an unintended, moonless, night exit on Holy Cross trail. Trying to pick lines through large boulder fields with a handheld Dewalt flashlight sucked (I did add Trucklite LED headlights immediately after this trip).
My goal was trying to find versatility and function in light placement without the appearance of gaudiness. I am not a big fan of monster light bars. I tried to find good deals on both eBay, Rigid, and Diode Dynamics (during their end of year sales). Lighting is ridiculously expensive and I did not have the appetite to pay even close to retail!
Here is what I ultimately came up with for this build...
I used Fluxor windshield hinge mounts. Big thumbs up to these mounts! I mounted 6" Rigid 360 Pro spots (white LED) with amber covers. These suckers are face melting bright.
Rigid D Series Side Shooter Pro floods (white LED) with amber covers for my ditch/corner lights. I fabbed aluminum brackets to attach these to my front bumper.
I cut a damaged roller fairlead and made a custom mount for a Rigid E-Series 10 inch Combo Spot/Flood (amber LED) with a clear cover. 1" aluminum spacers and 1/4-20 hardware bolted the bar to the bracket.
I used Procomp rocklight pods in white. These attached to the GenRight front inner fenders, inside the middle rocker body mount, and a custom aluminum bracket in the rear wheel well.
Savvy taillights were mounted.
I added tabs to my tire carrier to mount Diode Dynamics Stage Series 2" SAE/DOT Pro pods (white LED).
The final piece to my lighting puzzle was steering lights. I am on the fence about these being functional or a gimmick, but they do a good job of illuminating the direction the tires are pointing from a lower vantage point. I have big shoulders, flame away.
I am not a fan of cobbled together wiring or rat nests. Everything was wired using Deutsch connectors and heavy wall automotive PVC jacketed wiring. In many instances poly tube sleeves were added for additional protection. Everything was routed to the Switch-Pro power/ground bars located on top of my X2Power battery.
Looking back, I might have tipped towards the gaudy mark, but I will never hold a flashlight out the window again. This thing lights up like a spaceship now!
