Tie rod questions
FF_Jeep
Nashville, TN, United States
Under the assumption that my steering was OEM, I recently purchased the Crown HD steering setup to replace mine due to busted tie rod ends and a busted boot/dust cover on the end of the drag link. After I received my Crown HD unit I did the research I should have done prior and realized that the PO had installed what I can only assume is a junkyard ZJ upgrade(yellow paint markings on the tie rod). I've read that the ZJ is essentially the same as the crown unit so my dilemma now is should I A: return the Crown HD and install new ends and a new dust boot on the drag link or B: just install the crown unit and call it a day.
If I go option A I get to add money back to the Jeep fund. Option B gets me complete brand new steering.
Oh damn. Questions like that are like the last question on who wants to be a millionaire. I would change the ends and leave the zj bar see how that goes first
Sent from my SAMSUNG-SM-G935A using Tapatalk
Amazon returns are easy but since you made the mistake and not them, you will likely be charged return shipping. I would just run the new set up. You know it is all new and exactly what you have.
Reactions: FF_Jeep
I agree with @Rob5589, just install what you purchased and have a new setup.
Thanks guys. This was the conclusion that I had come to myself. Just couldn't pull the trigger without a second opinion.
Reactions: Rob5589
