Tips for wheeling on dunes
My first bit of advice, do not wheel alone. Someone always gets stuck, especially newbies. Expect it as part of the fun. A good long tow strap and shovel is good to have. The standard TJ jack using my cooler lid as a base is all I use out there for lifting. I have had to change tires before. Carry lots of water, it gets thirsty out there. 10lbs is usually okay for the tires, I have run at 5lbs too. Carry a compressor. Now, speed is your friend. Gravity is your friend. If you are going up a steep dune and you know you aren't going to make it, immediately steer down hill before you lose momentum. If you get stuck at an extreme sideways angle on a steep hill, open the downhill door, it may keep your rig from rolling until you get it down. It is better not to get stuck like that, know when to hold them, know when to fold them. We use tall flags on our rigs and we use GMRS radios (no CBs here). If you get stuck alone, put it in low range, steady throttle and steer from side to side. That usually will get you out. Jeeping on sand is more like snow mobiling. I do not use my AC out in the dunes, a JK needs to unplug the traction control relay under the hood. The small ruddy dunes are harder to navigate than the large ones. You need enough speed not to get stuck, but not so much that you go airborn into the unknown. There is a reason our sport has names like rock crawling. You crawl. We say dune bashing or smashing. You tend go much faster over bumps, rough ride, some puke. Only put people you hate in the back seat. I don't use my rear seat out there. BTW, the lighter the rig, the better, ditching the doors, top and rear seat makes a dramatic floatation difference, but know this, no doors or top = lots of sand inside the rig. I usually run in 2nd gear high range, rpms 2500 to 4000. BTW, always pack an awesome picnic lunch. No adventure is fun without a little gluttony. Lastly, have fun and remember, when in doubt as to what to do in a situation, cram the pedal to the metal.
When I go to the dunes I go as light as possible. Usually just a strap, and shovel. No spare I leave tools at camp and if there’s more than just me no winch. If it’s nice, no top at all or doors or windshield frame. If just me and my son and if my wife doesn’t want to go, no back seat or belts. 6-8 psi and 4hi. Sand is the most fun I have in 4hi
Reactions: reddvltj
Another note: You should discover if your bump stops are properly matched to the rest of your suspension if you had the proper amount of fun.
As @pagrey said your passenger could be used as one in a pinch...😁
It’ll be my wife & two kids, I love them all too much to go that route.
We will be taking the dogs, ones a neurotic mutt I don’t care for that weighs 60 lbs, the other is a fat lab clocking in at 70 lbs. If it came down to it....
Reactions: reddvltj
No idea if they’re matched or not. What do I look for, a chipped tooth & sore neck when I land?
You tend to bottom out the suspension. I look for tire gouges and sculpturing in the fender flares. Adds character. Sore necks for those with troublesome vertibrae is not unheard of. My wife will not run with me when I go out with the lads. Puts her in discomfort and I suffer from a week of missed oral ahhh...dissertation. Utterly tragic.
Reactions: qslim and reddvltj
Don’t know what those are. A snake & a potion?
Razor backs are on one side (back side) of dunes. Kinda like sand cliffs when ya hit the top of a dune I usually turn and get off the gas so if there’s one I don’t launch my jeep. There easy to go down just slower and straight. Can be tough to go up but fun to try
Witches eyes are like visible holes in the sand. They can get ya stuck pretty fast
Reactions: reddvltj
We will not be ripping it like like that, just cruising & keeping an eye out for dirt bikes & RZRs. Find a nice pond & have lunch, hopefully the neurotic mutt will run away.
Here is a pic of a razorback with a witches eye at the bottom
More often than not, when I head to the dunes I leave the Jeep at home... 😉
Be safe and have fun!
Reactions: Mumblewood
think about where you stop. always try to have down slope in front of you. Nothing like stopping to get a snack then jump in ready to go and then get stuck in your tracks. You will be surprised at how easy it is to dig yourself in on just a little up slope.
If your not moving forward stop spinning the tires. Keep in mind that creeping is moving and sometimes that is what it takes to get momentum up. I say momentum is your friend but on a hill climb once it starts the jeep starts hopping either turn back down out of it or get off the throttle. Backing down a hill in sand is not fun.
On a different note, you will love how the sand scrubs your tires clean. Make sure you pressure wash when you get home. sand and salt will take its toll if you leave it there. If you have not added drain holes in your frame do it soon after you return home and go back to the car wash.
I love dune running. I have not done it in years but It is fun, enjoy your trip and drive even more defensively!!!
Reactions: fixmysix and qslim
I don't know what the sand is like out in Wyoming but you might want to be aware that sand can be very inconsistent in it's properties. Wet sand and dry sand are the most obvious but the sand can be very different from the trough between dunes and the dune crests. Also from the windward surface of a dune to the downwind surface. All in the same area it can go from a nice firm surface to bottomless sugar-sand. In softer sand it can be helpful to coast to a stop without using the brakes. Braking hard can build quite a "dam" in front of your tires which makes it tougher to get going again. Far and away the most dangerous item will be the other good citizens out on the sand. Keep your wits about you in the presence of other dune dwellers!! I'm envious,...you and your family are gonna have a blast!
Reactions: qslim
Well we made it, that was a ton of fun! Y’all weren’t kidding about momentum being your friend, I lost some on a couple of climbs & had to roll down backwards.
We didn’t go too far in because we were by ourselves, we stayed about 1/2 mile from the BLM camp where a bunch of toyhaulers were parked with people ripping RZRs & ATVs. Scouted around some dunes to make sure they didn’t drop off too steep on the other side & let it rip. 8 PSI, 4 low, & a shovel did us just fine. Stopped for lunch, let the kids & dogs run around, it was really a lot of fun. Thanks for the pointers!
Reminds me of a trip to the dunes in Florence, Oregon some six or seven years ago. I pulled a Dukes of Hazard. :ROFLMAO:
