Last night I went to rotate the tires on our 01 Sport. It's pretty stock. Decided I should check the brakes while at it.
There was a lot of dust, but they appeared ok for the most part, I figured they'd get us through summer no more than my daughter drives it. I sprayed the dust out with compressor, then lubed the drum hardware and brake cleaned the pads. I put the drums back on the rear, and put tires back on.
Tonight I had to move it and sounds like a tire is sticking and something is creaking. My daughter failed to tell me this and despite knowing better, I didn't drive it after messing with last night as I didn't really change anything.
The passenger rear was really grimy looking prior to this, which is why I cleaned them all.
Any clue what I did? I've changed many brakes never had this happen. I guess I'll go ahead and get all new pads and I'm debating new rotors and drums depending on cost of new vs turning.
I've been eyeing power stop brakes for my yukon and they appear cheaper for the tj, than the brake select or ac Delco stuff at O'Reilly. Thoughts? Not sure if daughter should drive this until I figure out what the heck is going on.
