hi guys, so my trackbar heim joints took a dump finally. I had a superlift trackbar with the heim joint on the chassis side and the bolt for the axle is bigger than oem, I dont remember the exact size, it was put in there years ago, but the hole was drill in the metal plate on the chassis for a bigger bolt. Im just going to replace the whole thing since its rusted out anyway. Would the bigger hole in the axle side be an issue? Whats the consensus for a good front track bar? i have 3" of lift. or since its drill i have to order the same trackbar?
Edit: the axle side is 1/2" now, and the chassis side was drill 5/8
thanks
thanks
