I am a new member to the forum .
I have a 1997 Wrangler Sport , 4.0L , Manual 5 speed transmission with a NP 231J transfer case , pure-stock equipped other that 31x10.50x15" tires . Current mileage is 274,730 .
When releasing the clutch and vehicle begins moving , there is a squeaking noise that sounds like dry , worn-out u-joints , but noise only happens in 2 wheel drive . when transfer case is shifted into 4 wheel drive , the noise does NOT occur .
I first presumed that the u-joints were bad (considering the mileage on the vehicle), so I replaced the u-joints on both rear and front drive shafts , and both axle-shaft u-joints .
Then I drove the vehicle again , and still had the same noise when beginning to move forward from stops . So , again I shifted the transfer case into 4 wheel drive , and the noise stopped when beginning movement from stopped position .
Next , I removed the front drive shaft from the vehicle , and did a test-drive .
With only the rear driveshaft in place , the noise was still present when beginning movement from stops , with transfer case in 2 wheel drive position . However , when I shifted the transfer case into the 4 wheel drive position , the noise was not occuring when movement began .
I am certain that the squeaking noise is within the transfer case , I think that maybe a bearing or bushing that supports the gear-shaft is bad , but I have never opened to inspect or rebuilt a transfer case , and I can't locate a detailed diagram of the internal components of the transfer case .
I really don't want to buy a new or rebuilt transfer case if possible .
Do any of you have experience repairing/rebuilding the NP 231J transfer case ?
Thank you for any help that you offer .
DMP25-06
DMP25-06
