Transmission cooling line
elitx
Houston
Bent my 1997 Tj transmission Cooling line having trouble finding a replacement any idea where I could find, or a part number also I found one for a 1998 and was wondering if that would fit my 97 or they different
I believe the radiator and transmission fluid lines are the exact same between ’97 and ‘98 automatic TJs…
If you can't find one, you could always run a barbed fitting into the radiator, cut the metal line and flare the end, get a piece of transmission line in the length you need at an auto parts store and use hose clamps on each end to hold it on.
