Hi Folks,
First post here, but I have been reading a lot.
Jeep: 1999 TJ 2.5 manual transmission
Here is the problem: When I drive a short distance (maybe 5 minutes) and it is not hot, still winter in Montana, the Jeep won't start unless I let it sit for 10-15 minutes, then it starts right up. When running, it is smooth and has no issues regardless of the length of the drive. I should also say that the rig passes a smog test.
Here is what was done before I purchased the rig:
Fuel pump changed (maybe regulator but it wasn't listed on the receipt)
Fuel Injectors changed
Fuel hoses changed
Fuel tank washed out
Coil changed
Throttle Position Sensor changed
Here is what I have done:
I checked the ASD relay. It cycles on for a couple of seconds when the key is turned and I can hear the fuel pump running. It is also activated when I am cranking with a no start condition. I can tell this by examining the PCM fuel injector signal. It starts at 12VDC and that is supplied by the ASD relay, so to me that seems normal. I also swapped the ASD relay and the horn relay just to see if it made any difference. It didn't.
I checked the fuel pressure. It seems very high and the guy that owned the rig before me had the fuel pump and fuel injectors changed. The fuel pressure reads about 90PSI. I did let the fuel system sit for a while and I didn't see a bleed off of the pressure which indicates to me that the injectors are not flooding the cylinders with fuel which would need to be reduced before the spark plugs could fire.
I connected an oscilloscope to the low-voltage side of the coil and to the PCM side of the injectors. When the Jeep is running, I see the signal to fire the injector followed by a signal to the coil to cause a spark.
When the Jeep is cranking and not starting, I am seeing the signal to the coil, BUT, I am not seeing the signal to the fuel injectors. This is to say that the voltage on the PCM side of the injector stays at 12VDC and I am not seeing a low pulse which would fire the injector. The PCM is not activating the injector during this crank but not start time. I used starting fluid and the Jeep wouldn't start which is weird since I am seeing a signal to the coil so I should be getting a spark. I only checked this once, so I am not 100% sure I don't get some firing on starting fluid. I can check this again.
This led me to think that perhaps it was the crank position sensor since when I disconnected the current CPS, the Jeep exhibited the same symptom, in other words, it would crank but not start. Also, no codes are being thrown. It doesn't even throw a code when the CPS is disconnected and I am cranking.
So today, I changed the CPS and the problem persists.
What I haven't done is to verify the 5VDC signal at the CPS during a crank but not start condition. I am thinking of adding some wires to the CPS connector to see if maybe 5VDC is not present during the issue. That could be a PCM problem. I also haven't changed the Cam position sensor.
Soooo...I am interested to see if anyone has any ideas that I can try before I bite the bullet and change out the PCM since they are kinda pricey,
Thanks in advance,
Bridgerman
Fuel hoses changed
Coil changed
Thanks in advance,
Bridgerman
