Thanks for the recommendations!
dont get me wrong, the viair is better but I understand that you are a student and that you are trying to save as much as possible, I got those two articles and they have been just fine...
IMO, a quality air compressor is something that's worth investing in. Even if you only use it sporadically, it's worth spending a little more money on something that will last you a long time. I've been using my Viar compressor for 10 years now.dont get me wrong, the viair is better but I understand that you are a student and that you are trying to save as much as possible, I got those two articles and they have been just fine...
@Austin O., you have plenty of good advice here. I'm just glad you are doing it. And by the way, you have a beautiful TJ. It is very, very nice. They are so much fun. Summer is going to be a blast with the top off! There is nothing like it. Doors off and you've hit the closest thing to heaven this side of eternity.
I bought my Jeep over 20 years ago and all it had was 31s and a 4 cyl. Back then, like you, I didn't have a lot of money to put into it. I had big dreams of a lift, new tires, lockers, a winch, armor, and enough lights to be seen from space. After 23 years, the best upgrade I ever made was in seat time. The experience gained from learning to wheel what you have will guide you on what you actually need over what you think you need. To this day, I've really only added a 4" lift and tires. I have the time of my life and I get a kick out of the look on others' faces when they realize I took my open diff, 4cyl up the same obstacles they did in their fancy new Rubicon. I'd suggest a good air compressor and some recovery gear and then go wheeling with your dad. Should be good times!
Yall recommended front sway bar link quick disconnects... I cant find any for a small lift (planning to do 1.25 inches). Everything is 2 inches or more. Am I missing something?
JKS Quicker disconnects aren't cheap, but their part # 2000 fit TJs with 0-2" lift.
Do not over think that you have to do a bunch of mods to go off roading in your Jeep.
I live Dirt Every Day just to drive down to the paved county road.
We use our Rubican to get out and explore old mines and prospecting with our metal detectors.
Air down? Never do that no need too.
Sway bar disconnect Never do that either.
I drive in either 2wd or 4wd low range.
With the limited slip in the rear axle I can drive in deep sand and not get stuck in 2wd
If it get really bad I shift in to 4wd low range.
I have been off roading since the late 1960's, I learned how from my Dad.
He went everywhere in AZ and Calif deserts in two wheel drive pickup trucks back in the 1950's
Prospecting for mines.
My dad learned from old timers who went everywhere in Model T's.
@Austin O. I assume this is your daily driver, and I know you're on a tight budget. I suggest you think minimalistic. Your Jeep is capable of riding around at Uwharrie as is, you just won't be doing any of the harder stuff.
1) sway bar disconnects are relatively cheap and allow you to keep your tires on the ground more.
2) get some good AT tires like BFG K02 when the time comes. AT tires will be quieter and last 2-3 time longer.
3) consider a 2" spacer lift, and maybe a 1" body lift, both relatively cheap
I'd focus on those 3 things first.
4) when the time comes, spend the money to have your Jeep geared correctly for your chosen tire size. This is the time you'd consider a different differential, like a limited slip or locker.
