All speakers will be on amps. Budget is flexible. I'm going to replace my Kenwood KDC 258U with a better quality headunit with bluetooth not sure what yet. I will replace the sub in the center console that isn't hooked up (im guessing since PO put in the aftermarket HU). Either a 5 channel amp or a mono amp on the sub and a 4 channel on the mids. Speaker pods in the dash wrapped in sound deadening and poly fill and some poly in the sound bar.I always ask what you are looking to accomplish before making that kind of suggestion. Will you be amplifying these speakers and what do you want to budget for them.
The Kicker C and D series are fine plug and play replacement to use with the stock head unit. You can either get 5.25" all around, or get 5.25" for the front dash, and 6.5" for the overhead pods, which will fit.
Next brands up that I recommend are BLAM's Relax series and Audiotec Fischer's Match series, both are under a $100 for each pair for speakers. Then after that I would recommend Audiotec Fischer's next level up, Helix, but you would need an amplifier for that.
These are a great speaker that do not need to be amplified, can be driven off the head unit
https://www.ebay.com/itm/273557553743?campid=5337789113
https://www.ebay.com/itm/123080257637?campid=5337789113
As for components, well, you can create many awesome combinations, that will depend on the budget, but my favorite, and most bang for the buck audio upgrade for the TJ is changing the front set-up to components, and relocating the tweeters to the dash. It is great...but budget and time is needed.
I've seen your recommendations on the Match Helix stuff. Not 100% sold on those yet but for the price I just might try em out.
Was thinking about a midbass in the soundbar and components in the dash with the tweeters in the corners on top.
Do you know what the mounting depth for a subwoofer in the center console is?
