Hello everyone! I'm at a dead end with my TJ. First off, I'll list my set up:
2003 Rubicon Tomb Raider
6" Rough Country Long Arm Lift
Rough Country HD Steering Upgrade
33" Faulken ATW3 Tires
So after doing a 1" Transfer Case drop replacing both driveshafts (SYE)/U joints, new axle bearings, ball joints, control arm bushings, sway bars and links, drag link, stabilizer, AND swapping out the old rear (someone put a circle k pinion, a dana ring gear and yukon locker with a shim on the sun gear. Was also two dif ratios. Yes I know, it shouldn't have went down the road. It did...poorly.) Now putting the correct rear and housing did eliminate some of the vibration. It used to come on about 35 mph, now it's not til 55-60. My spedo is reading true as well, previously if the speedometer read 35 you were actually going 25. Tires are balanced, operating angles are maxed in spec. Any ideas would be greatly appreciated cause I'm outta ideas and running out of cash lol
Thanks!
Thanks!
