Swapping in the 8.25 rear axle for two reasons....one because its much stronger than the dana 35 it is replacing....thicker axle shafts...much beefier axle......and the second reason is the Liberty instrument cluster that we're using gets its speed signal from ABS system...necessitating the need for the axle swap...abs sensor is located at the top of the differential on the 8.25 axle...
