That's the big upside of the 4.25 kit, almost everything stays when you decide to upgrade.
Ahh, I see the adjustable control arm option now.
No uppers, but those can be added.
why does the combo kit not need a t case drop
do you know what the cam alignment kit and rear pinion cam locks do?I'll add that as far as budget lifts go, I don't think you can beat Zone for the money. I put their 3" on my LJ in 2010 and it did fine for what it was, which at the time was a daily driver with a single annual trip to Colorado to wheel in the Sa Juans. Being an LJ, the 3" lift didn't cause vibes even without a transfer case drop, so I got away without that or an SYE and the 3" keeps the stock arms. If you're on a budget and want to get it lifted and can wait for the other stuff, definitely don't even think about Rough Country or Skyjacker or any of the others in that price range, Zone is the way to go.
Personally, knowing what I know today, I would just drive it stock until I had the money to do Currie 4" springs with Rancho RS5000x shocks to match, Currie or JKS track bars, Savvy arms, and an SYE all at the same time. It'll end up in the $3k neighborhood at retail prices but you'll go from stock to a really capable rig overnight and you won't be redoing work and re-replacing parts over and over again like I've been doing for 3 years now.
The MML eliminates the need in most cases just like @Cornbread said. It isn't rare, call Zone and talk to them, they will give you an honest answer.why does the combo kit not need a t case drop
The MML is helping fix the issue instead of T-case drop. T-case drop sucks because your losing ground clearance on the skid plate that already has shitty ground clearance. Some have had to add body washers, I did not.why does the combo kit not need a t case drop
got it thanksThe MML is helping fix the issue instead of T-case drop. T-case drop sucks because your losing ground clearance on the skid plate that already has shitty ground clearance. Some have had to add body washers, I did not.
so is it a better idea just to get the adjustible arms and have an alighnment shop alighn everything?the cam alignment kit is to allow a small amount of adjustment to the front axle's caster angle.
I'm not familiar with rear pinion cam locks but they may be doing the same thing in the rear for pinion angle. It doesn't allow nearly as much adjustment as adjustable arms and doing that in the rear has fallen out of favor because they're known not to hold their position, unless Zone has done something to fix that.
thank you i will definatly read up on thisyes to adjustable arms, but I wouldn't mess with an alignment shop. If you just get adjustable lowers and keep the stock uppers, it's maybe a couple hour job with a $30 magnetic digital angle finder from Harbor Freight. I'd write up a summary of how to do it but there are threads in the How To section that do a much better job than I could.
i plan on mostly light rocks and overlanding type stuff and this will be my daily driver.I bought that exact kit for my Unlimited. Currently I am only running the springs and rear sway bar links that came with it and the bump extensions. I replaced the control arms with Savvy double adjustable all around, and I have the JKS front sway bar links. I also did not do the re-drill of the front track bar. I used a Rusty's off road track bar. I do understand Rusty's is hated and I do not promote them. This track bar is nice. I replaced the shocks with Old Man Emu.
What type of wheeling terrain do you see yourself hitting most often? Cause even though Zone is regarded as decent entry level stuff (which it is) over skyjacker or rough country. I myself would steer a person away from it at this point. Unless price is your biggest driving factor. I say try and save more cash and go straight for piecing together or buying higher end parts. At the point I am at I regret not just going straight to Savvy 4" coils. With some Rancho 5000x's or OME shocks. Or perhaps the Savvy Tuned Fox shocks, maybe.
I am still going to see how the Zone coils handle being flexed out while wheeling, will they sag? I'm not sure yet. I'm still finishing up my rig and will start getting out very soon.
I am running the rear track bar bracket from the kit also...
okay im definatly looking out for these thingsI think putting together a lift with the great info here is the best way to go if you have the money but beware. People will say just get a SYE and forget to mention that means an SYE and a fluid change and a new custom driveshaft. You have to carefully check all those little details and you might not know what the little details are. When somebody says $3k and lists a few parts, it might mean $4k or more when you are done.
You do not "need" extended lines according to the instructions. I did replace with longer lines from Russel. It does appear the stock lines would reach.does anyone know if i will need extended brake lines for this kit
