That frame looks so pretty!- Installed a 241 case and Savvy skid
- Installed a refreshed 44 rear, Savvy control arms, H&R springs, and other goodies
View attachment 238613View attachment 238614
I have no idea on that. I was looking at the full one and then the 2 piece deal. Jeep kept changing the design like every month it seems. I'm pretty sure you can swap a bezel for the airbag switch in that one. (If not, I've seen people 3D print some amazing things for out TJs and (my XJ)Im trying to replace my one piece '99 console:
(Note the front square hole that houses the airbag switch.)
With a later model 2 piece. With subwoofer. With the front coin tray with what appears like the same size square hole:
Trying to figure out if that coin tray hole will fit the airbag switch. Otherwise im just going to keep the airbag switch wired and try to tuck it under the front of the console or up under the dash.
Either way. The consoles are a quagmire to understand. I wish someone that knew did a pic heavy how to on exchanging them.
Installed 35s and found the illusive rubicon flares,lolLet's here what you've done to your TJ today!
I'll start by saying I gave her the biggest, most thorough cleaning possible!
I have a manual but I thought this was tried many times and no one figured it out.Wired my 05 Auto so the overdrive shuts off when you put it in gear
Hot sun. Lots of itIs this top actually going to fit? It seems SUPER tight already. I was only able to lock one of the Sunrider pins.
Mr. Taco, I found these for you.Cant find them anywhere, If I cut my own I wouldnt get an acceptable finish!
Baby tires.
Where?
Exact setup I have except the axles and hubs. But 4.56 with TT is a great daily driving setup.My TJ is FINALLY in the shop getting its 4.56 gears, True Tracks front & rear, chromoly axles & front hubs. I should get it back in a day or two to start the break-in process. ‘Can’t wait!
Thanks. I know that there are at least 100 different ways to do this, but for our application, I thought this was the best bang for the buck.Exact setup I have except the axles and hubs. But 4.56 with TT is a great daily driving setup.
I don’t think that’s a bad idea at all. I’d probably should have done new rear axles when I upgraded but since they aren’t broke, I’m letting them be. One day, I’ll change to rear disc brakes and get them done at that time.Thanks. I know that there are at least 100 different ways to do this, but for our application, I thought this was the best bang for the buck.
Changing the front hubs was an afterthought. The guy called me after the job started & suggested I change them because he could get them for $89.00 each & there would be no additional labor cost. That way everything will be new.
Attach the rear corners first, leaving the windshield latches unhooked. After time in the sun, you'll still need to pull the frame forward and do a little finagling to get those pins in. Mine's a bear even after sitting in the sun.Is this top actually going to fit? It seems SUPER tight already. I was only able to lock one of the Sunrider pins.
I think it was not figured out and people quit trying is more like it.I have a manual but I thought this was tried many times and no one figured it out.
