Taking wife to dinner in it.
Bragging non stop-
“Yeah, these are yer 5.9 Grand Cherokee vents. Not easy to find. Takes nerve to cut a hood. High speed grinder. Step Bit. Pretty dangerous procedure. @John Cooper and Triton ain’t done it. @Hog will. He ain’t skeered. Bet you won’t see another TJ with ‘em tonight.”
Chicks dig hood louvers
All over the place with my projects today...
Highlights:
Been working the heat gun and recovering plastic:
Compare the recovered driver side to the yet-to-be-heated passenger..
Column cover:
Working on my Windstar intake due to the GenRight fenders (inner & outer):
Went to bleed clutch with fresh fluid and found one slave cylinder bolt is broken & the nut is rounded out and stuck on the stud. These things are unobtanium - new one unlikely to be here until the end of the month.
Typical wrenching — making progress & making/finding problems....
Highlights:
Column cover:
Don’t that hurt the plastic?
'Not according to the internet'..... 😂 (because the internet is always right... lol) Damage can't be any worse than the condition of the parts before heating them.
Plenty of videos and walk throughs around of folks using it. I was very careful to avoid over-heating to avoid warping.
From what I gather, it brings the oils within the plastic back to life. You can easily burn off the 'texture' of components quickly so it's a delicate task. It 'snaps' from not-enough to just-enough heat to make the conversion happen. I used the under steering column part first since it isn't high visibility if I f'ed up...
Once the part hits the right temp for the 'oxidized' look to disappear, it's like spray painting, it spreads really easily across the part. I tried to 'swirl' the gun to avoid lines and cooling spots.
Waiting for tomorrow/ daylight.
Thats some good lookin winch line, Dumb question but im assuming that end is machined from aluminum right ? As well who makes that winch line
Im looking to get some synthetic line for my warn m8k to replace the steel cable, Was thinking about the "Freedom winch line" from BleepingJeep or simply some warn spydura line with a factor 55 end and call it a day.....The end 🙃
Reactions: Kiwi TJ
https://wranglertjforum.com/threads/wrg-winch-rope-on-the-website.73268/ made by @mrblaine of blackmagicbrakes.com and WizardRecoverygear.com
The thimble is also made by WRG. High quality and well respected.
The freedom line looks pretty cool,that being you don’t need anything else to start winching.but already having gear I went with the tre line and safety thimble.
I can still see your posts so apparently you haven't pissed me about enough to block you, so there is that.
Well thats good to know 😆
To add i feel as if i've pissed you off by my apparent dumb questions, I,e rollcages and suspension related stuff.....
But anyways have a good one sir 🫡
Reactions: ColoJeep
yeah thats the reason why i wanted it but ill stick with something more "conventional" and if i hear enough of how good it is ill give it a shot, looks like my money will go to Mr.Blaine's winch line 😀 alone with brakes some other day per say
Looks like the TJ will be parked for a while unfortunately. I got attacked by a conveyor belt at work Wednesday night and had to be flown to Inova Fairfax. After two surgeries in three days the doctors are optimistic about keeping my arm but it looks like my pinky might have other plans. I have a long road to recovery and probably won’t be able to drive a stick for a while or even work on my Jeep but I’ll still check in and try to help anyone I can. I have three more surgeries scheduled for next week. They’re flushing the wound out and applying artificial skin since I no longer have any on my forearm. Thankfully it wasn’t worse. Sorry for the gruesome pictures in advance lol
Wow! Sorry to hear about that, kincaid.0678. Prayers sent for a speedy and full recovery, my friend!
F*ck dude….sorry to hear about the accident…. Hope everything goes well in the recovery. All the very best….stay positive
