You can try and run a screw in the plastic and see if you can pull the dipstick out
Yep. Tried to run a drill down the middle but it just pushed it in.
I may squeeze the tube with a pair of vice grips to hold it, then run a screw down it.
Either way, the RMS is weeping about 3-4 drops overnight so, it's time.
Put a new Thermostat, Thermostat Housing and Radiator in the Jeep yesterday. Runs so much cooler now.
You can pull the tube from the block.
Duh!
Hadn't thought about that, even though the new dipstick I ordered comes with the tube.
I guess I can keep procrastinating the RMS!
Replaced the O-ring in the fitting on the radiator for the transmission cooler. It was a bit of a pain but seems to have fixed my leak.
At one point the o-ring went completely inside the cooler but I was lucky enough to fish it out with a pick.
Do the earlier (mine is a 2006) radiators come with a barb fitting or double flare instead of the push connects?
If I just want to replace the radiator v-brace, what would that require? I got one and had it powder coated. I can see the three bolt heads.
I really need to clean the engine. Make it more photogenic.
I haven't owned it that long though. It set for 3 years before I bought it.
Um, I’m not sure if I’m happy I clicked this link. This is a rabbit hole I promised myself I’d stay away from.![]()
Started working on storage this weekend.
I need to fit my 6' table, fridge, 13 gallon water tank, and lithium battery.
Just getting started.
This is a top notch project.
Got it to the point where it looks like everything will fit. I still need to secure the fridge and bins. I also will need to start mounting the battery behind the water tank and wiring the dual battery setup. I did make some mistakes, but I am using existing materials left over from other projects so I have spent zero dollars so far. I am happy with it so far.
Drove to my office this pm to chill out and nurse a receivable with a client that has me concerned.......big in vehicle rat problem in my neck of the woods lately - you guys know any tricks besides cats, Crosman air rifles and peppermint? Pretty sure I’ve been visited.
Big gopher rat
Aint havin it
Dude.. no way.
I'd move to another state.
I drove 14 miles and found out the sucker went with me …no joke. He bailed at my office.
I’m in a rural area and they are looking for water- they are about to find some - in a 5 gallon bucket set as a trap…
