The OP was last seen on June 4th which was page 1. Hopefully he took the advice in the first response he got and is ready to install the recommended 2.5” lift and go have fun with it.
Hope so. We moved past his question a long time ago.
And that is why these discussions are shitfests. There is zero discernible difference in any perceptible aspect amongst any of the TJ spring rates when the suspension cycles while driving the vehicle. You do not alter, improve, degrade, or affect the amount of body roll with ANY TJ spring.Stiffer the spring, the less body roll.
This is my viewpoint on springs, and I may be wrong but I believe it aligns with a few on here.
Springs affect the wheels recoil and rebound to and away from the vehicle. Stiffer the spring, the less body roll. Does this translate to more ride comfort? No, not really. The purpose of the shock is to take the input from the forces moving the spring and dampen (hmmm...) them and how it translates that movement through the vehicle which is where 98% of ride quality comes from.
Oh and side note, you’d have to use a cut down dump truck spring to prevent body roll if you don’t have good shocks and a sway bar. But if it’s not rolling due to the stiff springs, it absolutely will not work off road.
Exactly. So then comes the proposition - the stiffer your springs are, the less value and benefit you get out of your shocks. Using the adjuster on your shock or an even better shock (if we are using extremes) like a bypass, let’s you get all the tuning out of an easier cycling spring.Let's go back to my extreme examples. A solid block of steel and a Slinky that both provide the same ride height. One has a spring rate of several hundred tons per inch and the other can't even support it's own weight before collapsing without going solid.
So then the conclusion. Use the longest free length spring you can, that still provides the ride height you want, without having coil bind before your bumpstop. Boom, a great suspension.
Right, or loss of pressure on the dropped tire because not enough when the shock are extended. I also edited my post, because someone knows something and I wonder how they know it? Winning races?Correct, as long as it is understood that the desire for free length is simply to keep the springs from knocking around at full shock extension.
You’ll have to ask him if he can hang on but I’ve lost my grip and am currently falling backwards in slow motion while yelling the word “nooooooooooooooooo” GLIf the OP can hang on, he is getting a valuable lesson in where to focus his thinking and effort to achieve something worthwhile.
.... I also edited my post, because someone knows something and I wonder how they know it? Winning races?
Blaine you win, I agree it is a "shitfest".And that is why these discussions are shitfests. There is zero discernible difference in any perceptible aspect amongst any of the TJ spring rates when the suspension cycles while driving the vehicle. You do not alter, improve, degrade, or affect the amount of body roll with ANY TJ spring.
That’s why their “hi lines” work well, extra bump needed for springs means the tires never get thereMetalcloak pretends to know, but they forgot about the upward half of the equation.![]()
Blaine you win, I agree it is a "shitfest".Think of the good side though, endless interweb suspension experts make more work for you in the end.
Blaine has been in this industry for a long time, his brake kits are awesome and I buy them from Savvy regularly. Blaine builds some of the best rock crawler rigs in SoCal. Blaine is invaluable asset to this TJ forum, I just wish he would debate his suspension theory so new TJ owner could learn why or how things actually work, but I understand why he calls debate on the interweb a shitfest.Does that mean you are now in agreement?
Have you ever been 4 wheeling with Blaine?
Blaine's suspension is more KOH than DD.
When was the last time you saw a KOH winner loaded with the wife and kids stopped at the local In and Out for burgers and fries on the way home from Johnson Valley after their big KOH win?
Glad to hear your had a great week in Johnson Valley and you made it home safely. Sorry you had a driveshaft failure, was it an alignment issue?Yes. Well, no. Technically he had his in 2wd the entire time.
The way Blaine builds is equal parts KOH as it is DD.
My wife and I spent a week playing in the JV sand and played in the rocks the last day (unfortunately had a front driveshaft that was barely hanging on so couldn't do more). The next day we went out to grab pizza and drove over 2k miles home comfortably going the speed limit (80mph through a good portion of it).
When I join this forum my hope was it was different than Pirate or YellowBullet.
