If I can stick my face in this fire, would you also agree that a softer and longer spring would give the same ride height as a firmer shorter spring?
Assuming you would then I don't think you're disagreeing with
@Goatman.
Just trying to reconcile the different viewpoints
I see one side saying "springs control ride height" and another side saying "springs affect ride quality". I think both are right.
To further attempt to reconcile these two sides, follow me down the rabbit hole.
In my imaginary world I replaced my Jeep's OEM (not OME
) springs with the highest spring rate material I know of--cinder blocks. I used a concrete saw to set the ride height just the way I like and its stance looked great. In my excitement and eagerness to hit the trail I flung open the door and leapt into the driver's seat. As I backed out the tires ran over the crack between by garage floor and the paved driveway "Oof! I felt that!" I ran over a squirrel on the way to the trail "Oof! I felt that!" I felt every pebble under the tires as my brains rattled out. By the time I got to the trail I was so exhausted from the rough ride I had to turn around and go back home.
Obviously the stiff "springs" gave a poor ride.
Since I have friends who went to college I knew the way to fix this. I replaced my "springs" with the softest spring rate material I know of--air. It's hard for me to verbally explain what I did next but imagine the effect of the Jeep sitting on a 1 square inch piston in a mile long cylinder filled with compressed air. That's effectively what I did with some clever plumbing. I then spent the next three months running my air compressor to get the ride height I needed. But it looked great! You could barely see the plumbing poking out everywhere! In my excitement and eagerness to hit the trail I flung open the door and leapt into the driver's seat and... the Jeep bottomed out. The "spring" "height" was tall enough to get a good ride height on my Jeep, but the "spring" rate was too soft for the Jeep + the weight of me.
Obviously the soft "springs" were useless for what I wanted.
At that point I realized both of these scenarios had a problem with the springs. I knew I wouldn't be able to make cinder blocks compliant even by adding shocks, and I knew I wouldn't be able to keep my floating Jeep from bottoming out. And so I put my OEM springs back in and next turned to focus on the shocks.
Sitting on my shelf were a full set of Thomat65©™® shocks. Why yes I did make them all by myself, thanks for noticing how clever I am! You'll also notice that instead of letting the hydraulic fluid leak from the bottom half of the shock through the plunger into the top half of the shock (what a silly design! those fools!) I plugged those pesky holes and valves so it's guaranteed that absolutely no hydraulic fluid will ever escape the bottom half of the shock. They were foolproof! After slapping those bad boys on I flung open the door and leapt into the driver's seat and... to my satisfaction I noticed the Jeep didn't budge at all. Not even one little jounce. Down the driveway I went. As I backed off my inclined driveway and turned onto the road I noticed that as I turned and traveled over that angle where the incline met the flat road two tires at opposite corners were planted but the other two were suspended in the air. Yup, these shocks weren't letting the wheels travel at all! Who needs articulation when you have shocks like these! Being very proud of myself I continued down the road. I ran over that same squirrel again "Oof! I felt that!" Wait a minute... that can't be right... I had the most clever shocks in the world! But I ran over a few pebbles and sure enough "Oof! I felt those!" A few minutes later I had to turn around because my brains had rattled out of my skull again.
I called up my smart friends and in unison they said "obviously it's your shocks!" Dismayed yet knowing they had a larger vocabulary than me I decided maybe my clever shocks just needed some time to be broken in. But that had to happen later because I wanted to hit the trail now. So I did the next best thing I knew--I removed the shocks from my Jeep. It only took an hour and the Jeep still sat at the same exact beautiful ride height as before even though it had no shocks whatsoever. I was so excited because I knew
this time it was going to work! I flung open the door and leapt into the driver's seat and... the Jeep rebounded so bad it flung me right out the other side! Flying up through the air and landing hard on the concrete floor head first I woke up and realized it was all just a dream.
I think both sides would agree that there's a happy place in there somewhere. A happy place where the springs will comfortably support your ride at a good height over all the desired load ranges, and where the shocks will happily detune whatever is under the tires from your skull.
