My 2002 has it - I wonder if it's an NV3550 thing maybe? Does anyone here have an ax15 or 6 speed and also a shift light?
And is there anyone that drives by the light?
Nope, that's why the EPA changed the way they measured fuel economy in 2008. To match how people drive these days.And is there anyone that drives by the light?
Yes I have but it's almost like you don't understand I'm not stating my opinion on when to shift, I'm suggesting you to listen to Jeep if you want to know when to shift for economy. I hope that makes sense. That's exactly why I say things like "I don't know anything, that's why I listen to Chrysler" so you understand this isn't my opinion on the subject.Have you ever driven a manual TJ?
With a bit less than full throttle input, the 42 in my 04 TJ Unlimited shifts over 3600 and generally up to just shy of 4000.When do the automatics like to shift?
I have a '97 sport with an ax15. It has the shift light. I started out trying to shift by it and quickly realized there was no hope.My 2002 has it - I wonder if it's an NV3550 thing maybe? Does anyone here have an ax15 or 6 speed and also a shift light?
Maybe my gearing is off cause there's way I could shift at 3000 or 3500.
2500 is probably the highest I can shift my Jeep. And by 2500 its screaming for the next gear.
... refer to it as “not used”.
Now you have to share. What is your gearing, transmission and tire?
As far as I know the gears have never been changed. At least the person I bought it off of wasnt aware of it being done so who knows really. But otherwise they're whatever came stock on a 2000 Sport
Other than that just a 4.0 5-speed with 31"s
It sounds like your idea of a screaming engine is different than mine is.
Trust me, 2500 rpms with our engines is not "screaming for the next gear", that is less than 50% of its top safe rpm. You just have to get used to what is normal and shifting at 2500 is just too low of an rpm to shift at for most driving situations. Our Jeep 2.5 and 4.0 engines are commonly called "tractor engines" due to their near bulletproof design and strength. Don't be afraid of using higher rpms, they're where the engine runs best at.As far as I know the gears have never been changed. At least the person I bought it off of wasnt aware of it being done so who knows really. But otherwise they're whatever came stock on a 2000 Sport
...3000-3500 and the nose would drop when I let off the gas. I'll take a video next time I have a passenger with me.
