I want to run these aftermarket turn signals on my TJ. I have MCE fenders, and I do not want to do the grille relocation or use the go-to tiny 3/4" indicators. I've found some 12 volt, 3-wire LED turn signals meant for motorcycles that I think would make a clean install under the front lip of the MCE fender.
Description says "Black wire connects to negative, Red wire to running light and Green wire to turn signal".
https://www.amazon.com/gp/product/B09FPZM5RJ/?tag=wranglerorg-20
I'm not very knowledgeable on the TJ turn signal circuit, so I could use some guidance here. I know that wiring up LED's will require some modification to the wiring, but I'm not sure what that is. What do I need to make these work? Do I also need to work something up for the side markers, such as the 2-wire version of the 3/4" amber LEDs? https://performanceaccessories.com/led-marker-light-3-4-inch-amber-by-mce-fenders-led1.html
