Need some advice on, on upgrading my steering kit. Looking at Currie vs. Rubicon. This is for a 06 Wrangler unlimited.
X2 to this!The other nice thing about the Currie Currectlync too, is that it bolts right on, and you don't have to ream the knuckles or anything like that. It's truly a bolt-on affair. And yes, while it is pricey, you get what you pay for, believe me!
The Currie unit is very, very beefy.
Keep it simple with Currie's bolt-on Currectlync Heavy Duty Steering kit. It doesn't screw up the steering geometry so it doesn't cause bump steer like some kits can. Plus it is pure solid beef. I've had that kit on both of my TJs and would never go with anything else.
There are several things that could be going on causing play in the steering. You want to check everything from tie rods to track bar to steering box to pitman, et. al. If you find play in a component it is contributing to play in the steering.will this product fix play In steering? I'm not educated on steering systems
Exactly, you need to figure out where the play is coming from. The play could be coming from several potential sources. Do a "dry steering test" to determine where the play is coming from. With the tires on the ground, have a helper start the engine and then repeatedly turn the steering wheel back & forth while you look closely at all the moving steering parts to see where the play is coming from.There are several things that could be going on causing play in the steering. You want to check everything from tie rods to track bar to steering box to pitman, et. al. If you find play in a component it is contributing to play in the steering.
4" is recommended though you could get away with 2" if the bumpstops are extended 2". More info at https://www.currieenterprises.com/CE-9701Does the Curry system require a minimum amount of lift before it can be used?
I love the Currie setup as much as the next guy but what I absolutely hate is when their rod ends wear out and get play in them, it's another nearly $400 to replace them. I've got my eyes on the RE setup because it looks just as beefy as the Currie but uses Moog rod ends that can be purchased at your advance auto store for $30 lol has anyone used the Rubicon Express y-link setup?
