Looking to see who has replaced there pcm.
What company did you use and have you has any problems with the new/rebuilt pcm....and how long have you had it.
I will be buying a pcm for my tj next month if funds permit. Thanks
Is this for a 4.0L? My prints for a 2006 4.0L show that all of the O2’s share grounding location G105 which is on the right rear of the engine to the left of the oil filter.Thanks...my Problem is for all 4 02 sensors Heater codes. I cleaned up all my grounds and read that the o2 sensor grounds for the 06 are in the pcm. I have not checked the wiring or harness. Jeep runs great...166xxx....just engine light with codes. I will look into the wiring...before I buy pcm.
