ARB twin mounted inside the Jeep.
I have a dedicated pair of 4 gauge wires feeding a terminal block located in the back of the Jeep and the ARB is using that block for power with the ARB harness with a pair of 40 amp fuses.
The positive side of the 4 ga. wires has the 150 amp breaker located about 6” from the battery and after airing up a couple of tires it starts tripping and I constantly have to reset it to finish airing up. I initially thought I had a bad breaker so changed it out and the new one does the same thing.
The compressor is in a well ventilated area with sufficient air circulation and doesn’t appear to be getting hot prior to tripping. Considering people run these in the engine compartment in triple digit temps I don’t see how it could be too hot.
What boggles my mind is why the 150 amp breaker is tripping before the 40 amp fuses blow.
Anybody have any insight?
