T
TRE3TOP
Guest
Seems to me if you’re buying an axle to be hacking it up that much you’d just buy a bare axle housing.
He’s got me on ignore too. What a douche.Interesting... there's a page 231 but no post on it, and no #4601 post. Me thinks someone has me on their ignore list!!!
Edit... Spoiler I know who it is...HAHAHA
In answer to this some people already have or have easy access to known good axles for cheaper than what a new bare housing would cost.
Yeah, I keep kicking around the idea of finding a Dana 44 center (Like a JK HP center section), tubing it myself and then putting Dana 60 inner C's and knuckles on. Not because I need it, but because I think it would be a fun project. I'm weird like that. I would enjoy the engineering of it and the build process. Having a full machine shop (and professional guys to run the equipment) at my disposal means I can make almost anything...(insert evil laugh here).
Not to mention the proprietary BS you have to deal with going for dynatrac housings. Didn't @NashvilleTJ run into that? Had to order part from them and they were ridiculously expensive, compared to "regular" axle parts?A bare housing from say Dynatrac is $2K or more where as if you shop around you can get a HP44 complete axle from a 78-79 F150 for $200-400. And you can get it retubed for another $300-500 so you'd be into that axle for under $1K. Yes it isn't a high clearance housing like the Dynatrac but if you are looking at one of these axles you're most likely wanting to run larger than 36" tall tires. So IMO that difference in housing clearance isn't going to matter as much. So it all comes down to what you want and how much money you have.
Also as Mike said:
Some of us just like dinkin around with things and building things. And if you have the means and capabilities then IMO I say GO FOR IT....
Yup. From a proprietary "golden pinion seal" to non-standard front rotors that I had to buy from them.Not to mention the proprietary BS you have to deal with going for dynatrac housings. Didn't @NashvilleTJ run into that? Had to order part from them and they were ridiculously expensive, compared to "regular" axle parts?
A factory Ford axle will be cheaper to maintain, and you should be able to get parts for it for a long time.
Except that the least expensive Dana 44 center I found was almost $400 and I picked up two 78-79 D44s and a 9inch for $150.Seems to me if you’re buying an axle to be hacking it up that much you’d just buy a bare axle housing.
And then had to do how much work? I guess all I’m asking is the time and effort saving value worth it? To me it seems about like a wash or minimal savings for a lot of work.Except that the least expensive Dana 44 center I found was almost $400 and I picked up two 78-79 D44s and a 9inch for $150.
Also where are you finding 2 44s and 9” for $150, they certainly aren’t that cheap around here.
Just have to be patient and have the cash in the back pocket to pounce. And if you live where I do the extra work is cheaper than paying shipping from the lower 48.And then had to do how much work? I guess all I’m asking is the time and effort saving value worth it? To me it seems about like a wash or minimal savings for a lot of work.
Ah yes didn’t factor that into the equation. ECGS is a 4 hour drive from here.Just have to be patient and have the cash in the back pocket to pounce. And if you live where I do the extra work is cheaper than paying shipping from the lower 48.
That’s my biggest hang up currently. I don’t have a shop, I have a parking spot… the complex I live in is pretty cool about things, but I doubt they would want me doing much more than a weekend project on my Jeep(which is about the extent of my working knowledge anyhow)If you don't have a place to work on this type of stuff or the tools to do the work then yes I can see how buying a premade unit makes more sense.
MY example is bent tubing for a roll cage or for adding thigs to a cage. If you don't have a tube bender or know someone who has one there are tons of things that just seem beyond your reach.
I like building and tinkering with things, but the fabrication part of my life is a ways off. I’d love to have a shop one day, but once I’m finished with chiropractic school, my time will be better spent at the adjusting table - so I can purchase said shop!
