Now, summarize what you've learned for the class
Not to do SHIT the way Wildman does...
It will be interesting to get some first hand feedback on those calipers.Well I checked my ARB before I'd put the cover on. And realized that I can't use the fancy cover I'd bought because of where the air line for the ARB comes out. And when I checked the ARB I found out I had a air leak....I'd tried to use the square 0-rings and had lubed them up good but I still ended up cutting one of them. So I had to pull the carrier back out.
Put the round o-rings I'd bought and slapped it back together.
This FUCKING AXLE hates me... It has fought me every step.
So then I started on the new brakes for the rear. This axle came with Explorer brakes which IMO are too small for anything over 35" tires. So I'd decided to buy the Cadillac Eldorado calipers with the built in parking brake from Ruff Stuff and got their brackets also.
So I watched some video's on How To and read some install instructions and went and tackled it.
I'm using the same vented style rotor as what is on the front of the Jeep.
Actually wasn't that hard. I'll do the other side tomorrow and work on the soft like routing.
Hang in there, Dude. The axle doesn't hate you, it's just testing you a bit.
Yes it does. It's grenaded three times!The axle doesn't hate you, it's just testing you a bit.
Wound!!!This FUCKING AXLE hates me... It has fought me every step.
The first step if defeating your enemies is identifying the foe and that axle ain't no friend of wildman.Wound!!!
Meet Salt!!!
As someone who used to have to tell people how to make them work I can tell you they take a serious amount of patience to get the parking mechanism to work well.After a lot of the reading I did I wonder if the people who had complaints didn't setup the brakes correctly. So I'll be the ginny pig on them for this group.
Well it's tested me alright.
Biggest thing is to make sure you have the actual D122 and not D52 boxed as D122 and follow the adjustment procedure to the T.Well I've got the writeup that Ruff Stuff has on their website and I've read some other articles on the subject so I'm willing to TRY. I could never get the hat parking brake to work in the Explorer brakes so if these don't work I ain't any worse off. My last choice will be to install a line lock on the rear brake lines.
https://www.ruffstuffspecialties.com/R2262-A.htmlMake sure you have the correct pads first thing.
This picture concerns me, looks like you have a full float rotor on a semi float axle. Drums or rotors are hubcentric for a reason.
NAPA Part numbers for Front 4x4 Chevy Calipers and Bronco Rotors:
Caliper ONLY: LH - N4674, RH - N4673 - Both of these are LATER year part numbers
OR
LH - N4597, RH - N4596 - Both of these are EARLIER year part numbers
Ford 9" Rotor - NB 4885611 Premium Rotor. To use as a slip over rotor you may need to turn down your axle shaft flange
UP 85611 Ultra Premium
looks like schedule 40 vs 80 or the small tube equivalent.
you got those caliper brackets from Rusty's?
